So I bought a brand new 2017 Silverado about 6 months ago and the major selling point for me was the distance between me and the truck when unlocking and locking the truck. I had a 2011 before and you had to be right next to it to unlock the damn thing so I thought it was awesome to now be able to unlock this thing from a far distance away. Recently it hasn't been working from far away and now it's like I have to get right on top of it to unlock it or lock it.....anybody have any opinions on this? I just wanna hear what you all have to say before I go to the dealership
Please forgive me for asking the obvious (but you know it’s coming)...
Have you tried replacing the remote battery?
I wish I knew more about the electronics in these things, but they’ve reached a level of sophistication approaching magic.
M.
lol I actually started using my 2nd key fob and I get the same results
The cell phone app works extremely well although it's not the method you are wanting.
Yes it does!!
I wonder if taking the battery out and putting it back into the remote like restarting at computer would work?
But it does this for both key fobs
1 and 2
I guess I could try it anyway tho
Havent personally ever had this issue with my 17' but perhaps you could try the old top gear method:
1) Stand just beyond whatever point the remote entry stops working
2) Hold the end of the remote tight against the temple of your head and press the lock or unlock button
This will allow your body to become essentially a large radio antenna booster so If the remote entry then works its an easy way to know its a weak signal issue either from a low battery in the remote or an issue with the receiver within the truck.
Lmao haha
You're also assuming that both batteries are good. Try putting a new battery in a remote and see if the problem is gone.
True, I'll get some battery's and test it out
IT WORKED!! The new battery fixed the damn issue......it's crazy tho because the truck is only 7 months old I believe now
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
