Cool deal.. Where does the camera physically sit on the front.. If you have any pics would love to see it.
Zoom in under the bow tie, you can see the black little camera
This is it in motion...obviously a phone recording isn't gonna do justice but you get the idea!! I use this everyday in tight parking spots or whatever I want or need to see up front.
9e2a251c08874328e95ee8ef757f40ae.jpg I'll upload some more
Very Nice, clean looking... Now that it is installed do you love the location or would you go lower or higher mounting location on the grill. Just curious.
The dealer actually mounted it under the bow tie at first and it was not the best spot at all!! I remounted it where it is at now and I can actually see my front bumper which is very crucial in the mounting of the camera that way you can actually judge how close you are to the object in front
Do you know if there is a kit for the 2015 as well. I don't see it on the accessory site.
- scratch that. I see it now. It looks like an aftermarket kit.
Edited by shadowsnkx
This has hit the top of my birthday wish list.  Thank you,  jmiller11331!  Do grid lines appear when you get close to an obstacle?
No grid lines.. but it is very useful and helpful the way it is!! I can't tell you how many times a day I use it!! It's a great investment
Anyone know if this would work on a 14? [emoji51]
Thinking about doing this myself with the alpine head unit at same time.
Just wish this was a factory installed option from the get go like the fords.
Say what you want but IMO gm always seems to be a generation behind when it comes to trucks.
I wouldn't consider GM trucks to be behind any competitor.  The consumer has a significant impact on what manufacturer's will include in their vehicles.  I chose my current truck largely due to the fact that it feels like I'm driving a truck, not a computer.
On 1/1/2018 at 1:39 PM, Jmiller11331 said:
When it's all installed, just hold the back button on the infotainment system for 3 seconds and it switches to the front view and it will stay on the front camera until you hit the back button again!! What's cool is, you can drive with it on all the time
Does this interfere with the normal function of the back button?
Yes it's on the accessories website and it's $400 installed...I had a 20% off code and got everything for $300. Works amazing well and I am so happy with it
Jmiller, can you share the gm part number? Or a link to the item? Thanks.
I asked him earlier!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
