Which e fan?
So I have a 2004 2500 Suburban with the 8.1L / 4L85e that I want to convert to electronic fans. I have come across conflicting information in my search for the correct fan to install. Anyone have the "right" fan part number?
Do you want a factory fan setup or do you want to go aftermarket?
Factory set to bolt to your radiator would be - http://amzn.to/2FDSlS4
You still will need an adjustable relay kit - http://amzn.to/2myGImv
If you want an aftermarket setup this one will work perfect. It is what I am running on my 2000 2500 farm truck right now and I live in the south at the beach. http://amzn.to/2mvQpSU
You will need the adjustable relay kit for it as well.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
