I am on a mission to figure out how to remove the active grill shutter system from my truck without having to live with a CEL so I can install the RC 30" light bar behind the grill.
I have a Diablo i3 and can easily clear the code and reset the light, but it will just keep coming back.
I've read posts of folks hacking up the assembly and stowing away the motor with the stops glued to it?  This sounds too backwoods and unreliable for me.  There has to be another way.  Is this system controlled via the BCM?  If so, perhaps Chris White can hack the BCM to forget it had the shutters?
The light bar sits at the very bottom of the shutter assembly.  I know the bottom two shutters can be removed easily, but guys are saying the bar still won't fit.  I assume it is the "center spine" hump running vertically in the middle of the assembly where the motor is located that is interfering with the bar?  Can just the lowermost portion of this hump be cut out to make room for the bar?
Let's brainstorm together and make this happen!
Can I just remove all the shutters from the assembly and cut on the two yellow lines to free up the portion with the motor and stops?  Wouldn't this keep it all intact so I can just stow it away somewhere out of the way?  What is there to glue to the motor if I do it this way?
so what is the downside of removing this..?..
The CEL just keeps coming back because it thinks something is wrong.  Can be annoying when you know why its there and you want it gone for good.  Makes the truck seem a little less hacked together.
Decreased MPG, longer engine warm-up time in cold weather, and MOST IMPORTANTLY, "Check Engine" light is illuminated and codes are triggered.
Has anyone had a problem with this, replacing the grille? I just purchased a new grille and want to install but now worried I might run into a problem. Here is the grill
The grill is no problem - it goes IN FRONT OF the grill shutters.
I'm trying to install a lightbar BEHIND the grill - that's where the shutters become a problem.
Edited by lapoolboy
Ok great. I was worried about the depth. since this grill is more recessed. I wanted to install a lightbar also so hopefully someone can help.
While I really like my lights mounted behind the grill, I would give them up to keep the shutter system, if my truck had them.
My shutters make the heater work alot faster for sure. Comparing my 16 to my 17 I can say that definitively. Beyond the heater I don't know that they do much else.
I don't understand why everyone goes crazy for these LED lights that are illegal to run on public highways, and 2016 and newer lights are really good anyway.
These work great offroad if that's the goal though, as I have them on my Polaris Ranger.
Really surprised a company like rough country hasn't come out with a plug in error eliminator. I'm sure it would sell well with the amount of people wanting to remove these for various reasons.  I would hate to cut up the factory part as I',m sure its expensive (anyone know the actual cost?)
I ended up just getting the rough country Bull Bar with the built in 90W led bar because I couldn't be bothered with the amount of work to get the LED bar in the grill.
27023762_1736023849753315_2514904338691965312_o.thumb.jpg.4f570cffa47c72fde5c13c50f33433b6.jpg
That looks nice. What’s the brand?
Edit: I see it says race mesh now
  • 3 months later...
Good idea I think it should work. Have you tried to do your idea?
Sent from my SAMSUNG-SM-G935A using Tapatalk
1 hour ago, alodawg26 said:
Why are you wanting to remove this?
It's earlier in the thread.  He's trying to make room for a light bar behind the grille.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
