I didn't see this mentioned but having dot rated fog cubes won't do anything if they're not mounted and aimed at fog level. Mounting them up high is not going to work out as you'll end up blinding someone. I would lose the tint as that's probably the best way to go.
Cars and trucks have been sold with cornering lights that come on with the turn signals, when the wheel is turned, or both, for over 50 years. Watch any recent vintage BMW, or pre-2000 Cadillac take a corner and you can see the lights aimed about 45 degrees off center, sometimes mounted as part of the fog light assembly and sometimes as a separate light fixture on the fender, come on and stay lit for about 30 seconds after the corner is completed. Any shop that does custom lighting should be able to configure these for your truck. There are complete kits, but they could also be wired up using fog or driving lights aimed outward and a "cornering light relay" for an older car model that had them, like a 1980s or 1990s Lincoln Town Car; Ford probably still sells them as replacement parts.
I have a '17 LTZ with the led fogs... Part of me wants to take them apart and put LEDs in there to flood the corners, but probably a bad idea. Curious if there was anymore work on this one.
Sent from my XT1585 using Tapatalk
On ‎2‎/‎18‎/‎2018 at 3:29 PM, 74Sprint17SierraATX said:
I do a lot of driving from Long Island to Syracuse and prefer leaving at like 2am. Wanted a little more light, while staying legal.
I ended up buying a cheapo bar on amazon and some pods which seem to be doing it for me. You could do a smaller pod and a sharper angle for your turns (?) just a thought.IMG_0620.JPG IMG_0621.JPGIMG_0622.JPG
What is the name of this bar. I want to add a couple 8" light bars I have laying around and aim them like this to add to my 32" curved light bar hidden in my grill.
I thought this might be helpful for anyone wanting to do cornering mirrors that turn on automatically with the turn signals...
https://www.amazon.com/gp/product/B01CEICZLC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Definitely not the best quality, but it does what i need to do. Theres a few different brands on amazon.
If I were doing something like this I would use a transistor or FET with the R/C circuit to drive LEDs for cornering instead of another relay.  You could also use a potentiometer and tune the time delay for turning it off.
I'm not sure how these trucks are set up electrically, but if they have a standard flasher relay you could just get on the steady signal wire to the flasher relay or from the turn signal switch, but I don't have the electrical layout to see if that is possible.  It might just be easier to wire an independent switch or right to the fog light supply for this situation, though.
I have the Morimoto fogs on my 2015, they are significantly brighter and throw a much wider pattern than the factory fogs. They help me watch for deer in the bar ditches. I would whole heartedly recommend them to give you better light dispersion.
However...
timting your front windows so dark that you are concerned about being able to see at night is not wise. This could quite literally bring a tragedy into your and maybe someone else’s life.  One or two shades lighter tint is not going to ruin the appearance of your truck or significantly affect the cooling and protective aspect of your tint. There are more expensive tints that are slightly metallic and therefore more reflective from the outside, which creates the illusion of being darker. That type of tint might be a better fit for you. Be smart.
However...
I have no tint and have the same problem. Been dealing with it for 3 years. I have Morimoto HID headlights from TRS, but that doesn't help much. The fogs help some. But I, too, would like more light; particularly right turns. The entrance to my neighborhood is slightly higher than 90deg and I'm just hoping for the best when I turn in at night. Just poking around the Internet it seems several other folks of different makes/models have gone the route of the Ford relay. Chevy supposedly has a relay used in older model Tahoes, too, but I haven't found that p/n.
  • 2 years later...
I have a 2018 Suburban I want to add turning lights also. There is room in the lower air dam (black plastic) to add a small spot /flood. Just need to find the left right turn signal voltage before the flasher..Will add a relay..Has anyone done this??
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
