I'll bring it up again at my next service visit, it does not pass as "normal driving characteristics".
Running it in L5 all the time makes it 90 percent better.  It also disables V4 mode and the truck still gets over 20mpg.
I just bought a '16 with 12,000 miles on it and it's clunks (hear&feel) while downshifting in most gears.  I stuck my edge tuner in there and tried a few different tunes but nothing helped.  I noticed the converter locks up in 1st gear and stays locked during every upshift while accelerating slowly.  When downshifting the converter stays locked until 2nd gear I believe.  The clunking is the worst from 4-3 and 3-2.  I'm pretty sure all of the clunking is because of the torque converter.  I'm use to my 4l60e and 4l80e only locking up after a set speed in 3rd and 4th gears.  There is no way it's normal for the converter to lockup when it does..
That's exactly the symptoms I have with mine, torque converter feels like it isn't unlocking at light throttle shifts. Any way to convince the dealer this is not 'normal operation'?
Sent from my Moto Z2 Play using Tapatalk
I hooked up my hptuners and experimented by disabling torque converter lockup.  As I figured, it shifted beautifully and overall felt so much better!  You can definitely feel the torque management a lot more between shifts though
The 4L60E was plagued with issues.
I had every one of them fail in various ways on my trucks ranging from 1994-2005
Are you guys experiencing what I am specifically?
When I go above 40 and coast or easy brake to a stop.  When its doing the 4-3, 3-2, 2-1 downshifts I feel a jerk or a tie up sensation and a release when it downshifts.  I also see the RPM's bump up (which is what I should see).  The jerks or bumps or tie up sensation feeling has been occurring since new on my 2016 5.3 6 speed.  I've brought this up quite a bit here but there tends to be no fix insight.  The dealer replaced valve body and TCM and has reset taps but nothing has fixed it.
Mine is more noticeable when it changes down under very light acceleration, also has the symptoms you describe if I change down manually while coasting.
Best description I've seen is earlier in this thread, clutches / torque converter not disengaging/slipping.
I just found this online:
https://atracom.blob.core.windows.net/webinars/gm/6l50_80_90_updates.pdf
6L80 Intermittent Harsh Downshift, Chuggle or Shudder During Deceleration 5.3L Tahoe, Suburban, C/K Trucks Customer complaint may be harsh forced downshifts or the chuggle/shudder during a coast down intermittently. This is considered “Normal” with this powertrain package. It is a self test for the O2 sensors. Test runs with the vehicle speed above 45 MPH (72 kph) in 6th gear with the TCC applied. The ECM drives the fuel system rich and then into deceleration fuel cutoff mode (shutting the injectors off) to check the system. Test will end during the deceleration and fuel is restored. (This typically causes the Shudder/Chuggle shift feel in the vehicle). Aggressive throttle response during this system check mode will cause the vehicle to have a “Harsh” downshift (this happens because the TCC remains applied during the test). If the test runs while in 5th gear, the TCC will not be applied and the complaint will not likely occur. Note: The test is designed to occur one time per key cycle, but can run up to 10 times if aborted due to throttle input.
Mine isn't intermittent as it does it all the time, it doesn't go away in M5.
Edited by nluchau
  • Thanks 1
I had brought mine in probably 10 times for the sh!tty transmission and they replaced different internals every time until I finally flipped out and made them get me a complete new trans. that was at 96k miles right before my powertrain was up. The "new" trans is somewhat better but the truck is still not peppy at all and it has no idea what gear to be in when you let off the gas pedal and then get back on it. At least it doesn't downshift so hard your drink spills...for now
Chevy missed the mark with these trucks.  Good looks and good interior but the drivetrain is trash. I surely wont be getting another anytime soon. I try and tell everyone who is thinking of buying a new chevy to drive it and see how terrible the trans is.
Good to hear from you again njk4o5!  Mine isn't downshifting where I'll spill something.  Its just annoying as heck still.
My 2018 will clunk in the same spot pretty much every day. On the 4 lane to my house there is about a half mile down hill coast, then a mile long uphill and right at the top is my exit that is also uphill that comes to a stop sign. Pretty much every day when slowing for the stop sign it clunks really hard on the 2 - 1 shift. I have a Range AFM disabler.
I experimented this week after some success with L5 driving.
L5 eliminated:
V4 mode
35 to 39mph shudders
80 to 90 percent of clunking
Then I tried Tow Haul mode.  The first few days of driving resulted in some gruff driving characteristics (holding onto gears for a few seconds more than necessary before upshifting)
After the transmission "learned" my driving style,
it is better but still hangs on to gears for too long
L5 with Tow/Haul eliminated:
Early upshifting
Gear hunting
Clunking
The usual V4 mode demerits
In summary, running L4 under 50mph and L5 for everything else solved everything.  T/H was too rough.  The truck is a breeze to drive now, L4 improved throttle response as well.
Edited by NorthEast
L5 eliminated:
V4 mode
it is awesome
Early upshifting
Gear hunting
Clunking
L5 with Tow/Haul Maintained:
20+ mpg in mixed driving
In summary, this setup made my truck normal (not a shitbox).  In suburban/semi-urban driving, the gear-holding prevents unnecessary upshifting. Staying in lower gears gives significantly better throttle response, even with small inputs.  No more gear jumping when getting on and off the gas.
Highway driving between 55 to 70 is a little louder because it revs at a constant 2k, but still returns good fuel economy.
I think these truck come from the factory in some form of a SuperEco mode to score good EPA results.  L5 plus T/H brings them back to reality.
good to know, im going to try this on my way home from work tonight. good write up thanks
    BrandonFranceschi
    BrandonFranceschi
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
