aftermarket tow mirrors
i have a 2016 GMC Sierra 2500 HD SLE . I have prchased a set of syppo tow mirrors that have running light , signal , cargo lamp and heat . my current mirrors only include adjustment and heat options . what do i need to do to gain full functions on these aftermarket tow mirrors ?
There are several threads here for this very subject. For full function you will need new wiring harness and then it's pretty much plug and play. Did the same thing to my 16 Silverado.
I’ve got you covered. Helped over 500+ members here.
PM and we can cover it all.
I just want to give a shout out to Phil Gamboa, he helped me out tremendously and I cannot be more grateful.  My 2015 had a rare anomaly that seems to plague only a certain amount of early pre 2015i HD's with the memory seat and carry-over camper mirrors.  The passenger mirror needed an extra jumper harness to make the fold option work, and he spent countless hours of research and development to build this harness and send it to me in what I consider light speed.  He is very professional and patient and in the days of crappy customer service, a shining star.  Please understand this build is not for the desk jockey, it takes care and a ton of patience.  In fact, if you have a friend or family member with tiny hands they will be your best tool in the box.  Anyhow Phil is the man, and he will go to great lengths to find THE solution.  Thanks again Phil!
Shawn
Shawn
Looks as though I need to update my sig with the new mirrors installed!
Shawn
Shawn,
Thank you for sticking through with this upgrade. Like you said, you had the anomaly of the builds. In the 500+ members I’ve helped, this issues would be counted as #2. There is another member who would make it #3. I wish I could remember who #1 so I could offer this solution to him.
Certainly appreciate your patience throughout all of this and glad we found the solution!
Please share some pics :)
Shawn
 Did your build still require the temp sensor in the passenger mirror? i have a early 15 ltz diesel with memory seat and old style camper mirrors as well. However my new mirrors are off of a gas truck and lacks the passenger side temp sensor. i was just wondering if it was really needed being I don't believe my stocks had it to begin with.. I have the rzy as well as Phils harnesses. Hoping to start install after next week when my vacation starts. happy to hear he has my only concern figured out should it become an issue!
You need the temp sensor. Without it your truck with throw a code and the check engine light will come on eliminating the remote start function. The sensor is used for the diesel exhaust brake. I would inquire with Phil further to see if it’s a possibility to add it.
So you installed the mirrors without the sensor on your early 15 truck and it threw a check engine light due to the temp sensor not being there? Are you speaking from experience?
No, I ordered the mirrors with the sensor, I did my research and found posts from this site and the diesel page concerning your issue.  Users trying to install mirrors without temp sensors got the result I explained
I get what your saying but those people that had those issues all had the sensor to begin with. Also others with the old style camper mirrors have changed mirrors with no check engine and have not had to add the sensor. What I’m getting at is if I didn’t have one before why do I need one now?
Ah, I see what you're saying, I was under the impression that our "old" camper mirrors had the sensor in them as well, so I tried an experiment.  I unhooked my passenger side mirror and started my truck, drove around up to temp and turned on the exhaust brake, everything functioned fine.  Maybe our temp sensor is in the grill?  I'm kind of baffled now because I was under the impression it was in my passenger mirror this whole time.
If your order style mirror didn’t have the temp sensor, you shouldn’t need it. Check the mirror itself and inspect for pins being present on slots 15 and 16. If your factory mirror doesn’t have pins loaded, you should be fine.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
