Max242 Posted July 9, 2020 Posted July 9, 2020 On 7/7/2020 at 8:17 PM, TX LIMO said: I have the one with the cubby installed on my 2015 right now. Looking to change it out for the trailer brake one to cut and install some light switches. I have the 4x4 version. Sent from my Cellular device utilizing a chat forum thingy. Thanks Steve, I'm not in a hurry at all. If you find yourself wanting to sell the rubber insert at sometime, let me know - Mark 1
Ravenkeeper Posted July 10, 2020 Posted July 10, 2020 18 hours ago, Max242 said: Thanks Steve, I'm not in a hurry at all. If you find yourself wanting to sell the rubber insert at sometime, let me know - Mark Max, If I stumble across the one from my 2015 Silverado, you can have it, just cover S/H.
Max242 Posted July 10, 2020 Posted July 10, 2020 5 hours ago, Ravenkeeper said: Max, If I stumble across the one from my 2015 Silverado, you can have it, just cover S/H. Thanks Steve, sounds good just let me know
TX LIMO Posted September 16, 2020 Posted September 16, 2020 Well I finally got around to installing my switches in the infamous cubbyhole panel. I took one with the trailer brake control cutout and modded it with a 2” hole to fit the switch pod. Unfortunately I did not have the correct wire sizes to wire up my fuse/relay/power distribution panel over the weekend, but gonna try and knock it out this weekend. Sent from my iPad using Tapatalk
bwlaqua Posted September 16, 2020 Posted September 16, 2020 Well I finally got around to installing my switches in the infamous cubbyhole panel. I took one with the trailer brake control cutout and modded it with a 2” hole to fit the switch pod. Unfortunately I did not have the correct wire sizes to wire up my fuse/relay/power distribution panel over the weekend, but gonna try and knock it out this weekend. Sent from my iPad using TapatalkLooks good. I have a trailer brake so going to have to find a different spot to place all my switches. I already have my dixie horn on center console by my leg. Easy to hit with my knee and piss off drivers who cut me off.Sent from my iPhone using Tapatalk 1
TX LIMO Posted September 16, 2020 Posted September 16, 2020 Looks good. I have a trailer brake so going to have to find a different spot to place all my switches. I already have my dixie horn on center console by my leg. Easy to hit with my knee and piss off drivers who cut me off.Sent from my iPhone using TapatalkNice. I want to upgrade from jumpseat to full console but can’t afford that right now. Would make life so much easier. LolSent from my iPad using Tapatalk
2014silver5.3 Posted October 1, 2020 Posted October 1, 2020 On 4/3/2018 at 3:54 PM, HoosierZ said: I epoxied a panel over mine and put my brake controller adjuster and LED in it. How did you epoxy it?
HoosierZ Posted October 1, 2020 Posted October 1, 2020 4 hours ago, 2014silver5.3 said: How did you epoxy it? I used some 2-part epoxy to bond a piece of ABS plastic over the pocket after I cut off the back of the pocket. Then, I sanded it smooth and painted it. 1
2014silver5.3 Posted October 3, 2020 Posted October 3, 2020 On 10/1/2020 at 11:40 AM, HoosierZ said: I used some 2-part epoxy to bond a piece of ABS plastic over the pocket after I cut off the back of the pocket. Then, I sanded it smooth and painted it. It looks great
BamaLegend Posted January 29, 2021 Posted January 29, 2021 On 4/3/2018 at 3:54 PM, HoosierZ said: I epoxied a panel over mine and put my brake controller adjuster and LED in it. Can you tell what all you used and done to cover that hole up? If I can’t find a blank trailer brake panel, I’m gonna need to do this to mine.
BamaLegend Posted January 29, 2021 Posted January 29, 2021 On 4/4/2018 at 10:54 AM, WSFD6107 said: Replaced my cubby hole cover plate with the trailer brake cover plate. Then cut out opening for my light switches. Trailer brake cover plate is flatter and accepts switches better with a "factory" like look. Where can I find the same trailer brake cover plate that you used? I have searched around and can’t find one. I’m wanting to do the same thing and add 2 rocker switches there for my roof light bar and the other for my light bar on my brush guard. I want that factory look like you’ve got yours looking.
WSFD6107 Posted January 29, 2021 Posted January 29, 2021 46 minutes ago, BamaLegend said: Where can I find the same trailer brake cover plate that you used? I have searched around and can’t find one. I’m wanting to do the same thing and add 2 rocker switches there for my roof light bar and the other for my light bar on my brush guard. I want that factory look like you’ve got yours looking. GMPartsDirect Part# Switch Bezel - GM (22830877)
alex___ Posted July 9, 2024 Posted July 9, 2024 Did anyone ever find that rubber piece or know where i can get one? Mine is broken and im having trouble finding it at all anywhere. Email me at [email protected] if you know.
