Zone 4.5
Like 1.5 or 2 inches on each side I believe.  Enough to throw rocks at your paint even with stock rims but I'm not a fan of running boards either.
How much does it widen the stance
1.5” per side
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
On 6/14/2018 at 8:29 PM, Tyy1907 said:
If it didn't widen the track width so much I'd want it hands down.
I'm not a fan of tires sticking way out either, but keep in mind if you don't widen the track at least some when lifting, you do loose stability.  A 3" increase for a 4.5" lift is pretty reasonable.  With 20's you can use the stock wheels with the BDS 4.5 so that helps keep it to a minimum, when you add aftermarket wheels with a much different offset on top of that, it can become excessive to some tastes.
