2 hours ago, starman8tdc said:
   Good info, thanks for posting.
   From what I have read, the direct injections systems are definitely superior to all the predecessors. I have been working on various cars for decades, but I have not had any issues come up with that particular fuel system.
   I will definitely study the system well before taking one apart.
It's funny you mention you haven't seen any issues yet, I haven't either. I ran into a code on a Hyundai a year ago and it pointed to the high pressure fuel pump, that's about it. Most of the complaints I hear about is the noise of the system.
I imagine most issues are still being handled by dealers because on some cars it's still relatively new. But Audi has been using it for years, haven't seen many issues except for worn followers on the cam. Come to think of it BMW was having some high pressure fuel pump problems with the 535...and some destroyed cams.
  • 7 months later...
I am having the same problem with my 2016 it started about 4 months ago with only 47k miles now; after replacing spark plugs, o2 sensors and going crazy... dealer told me I have a bad injector # 7 however the recommend to replace all 8 injectors and while we are at it replace the fuel lines at a "discounted" price of only $1800.  ( it stinks to be asked to pay that much for truck you are still making payments on)
The service adviser pulled all the lame excuses; he even told me I have been putting some bad gas in there, I told him that it was the same gas that goes into the rest of the cars in my household and none of the other cars have any issues. (a Ford and a Honda that are running like champs with more miles)
Gordon and Partners is a law firm that has a office in the same building where I work; they have filed class action law suet in the past against car makers before for problems such as this one... as son as get around to it I will let you all know if we have a case and see if you would like to participate.
Far more than the 535.  Anything with an N54 engine (which went in the 135, 1M, 335, Z4, X5 and perhaps others) all had HPFP issues to where BMW extended the factory warranty on them.  It is a guarantee that the early units will fail...though most have been replaced by now.  The latest revisions seem to be more durable.
Their DI injectors are also suspect and use the same injectors on a number of different engines.  They are up to Index 12 injectors now, with multiple part numbers per index, so there have been a ton of revisions due to how bad their injectors survive.
Fortunately, the GM injectors are very inexpensive compared to the BMW units...about 1/5th the price.  You can replace all 8 GM injectors for under $400.
  • 7 months later...
My 2018 Yukon was diagnosed by independent GM-certified shop to have entire bank of injectors to be out of spec. It rough idles, but no codes. Guess, what did GM say... dealer tested and rough idle is “within GM spec”. I am looking at the report prescribing them to replace bank of injectors... they are simply instructed but GM not to perform expensive repairs on injectors, and dismiss them by “spec”. Nobody has ever seen this spec... truck is 8 month old and 9000 miles...
  • 5 years later...
On 7/12/2018 at 7:29 PM, YJSONLY said:
They are soaking/ cleaning carbon off (no charge to me because I have authorized anything to be done!!) say that the 2 injectors was bad ( I wander if someone just messed up a gasket or seal and just say bad injector idk)
What does this catch can do? Or do you have a link that is informative? On my phone app is kinda hard to sift thru stuff
When discussing direct fuel injection, it's important to note that it uses a 60-volt system. Carbon buildup occurs on the back of the valves because fuel no longer sprays over them. To clean this carbon buildup, a crushed walnut cleaning system is effective, preventing the need for a complete teardown. BG Sea Foam will not clean this buildup.
Each gas injector has a code for high, low, and medium flow rates, and you need to ensure the same flow rate is maintained on each cylinder to avoid drivability issues, such as P0300 to P0308 and other codes. Sometimes, you might get lucky with aftermarket injectors, but it's crucial to match the code of the new injector with the one you remove to prevent issues.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,186 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
