04BlackMagic Posted July 26, 2018 Posted July 26, 2018 Are hazy headlights a common problem on 04 silverado? Sent from my iPhone using Tapatalk
Jsdirt Posted July 26, 2018 Posted July 26, 2018 Yep - UV and plastic don't play well together. Every car across every brand does this ... at least ever since they all collectively cheaped out and went to plastic, instead of GLASS. Get yourself some bug spray - something with at least 25% DEET in it. It's like magic - spray the headlights, and give 'em a wipe. Not a joke! You'll thank me later.
newdude Posted July 26, 2018 Posted July 26, 2018 Once you get them cleared up (if they are saveable) throw some wax on there once or twice a year. They will keep their shape much better.
diyer2 Posted July 26, 2018 Posted July 26, 2018 1 hour ago, Jsdirt said: Yep - UV and plastic don't play well together. Every car across every brand does this ... at least ever since they all collectively cheaped out and went to plastic, instead of GLASS. Get yourself some bug spray - something with at least 25% DEET in it. It's like magic - spray the headlights, and give 'em a wipe. Not a joke! You'll thank me later. Not a good idea according to this. This seems a good way. I have done quite a few headlights with my buffer and rubbing compound. Keep the light wet and not a lot of pressure to avoid to much heat. Take your time. If the lights are faded badly start with rubbing compound and no water for a more course first step. Then go with the water for a second step. I also use a compund pad(more course) on my buffer for the first step, then a finish pad for the final step and use water.
Jsdirt Posted July 26, 2018 Posted July 26, 2018 Bug spray is so cheap - one can would probably last you 5 years doing just headlights with it. If it hazes up, just do it again - cheaper than buying new lights, especially for a beater you don't want to sink a ton of money into. As for the paint damage, I suppose if you hose the headlight down and let it run and sit. Spray it on a rag, and wipe it on. If you're doing this to your headlights, you don't give a crap about your paint anyway.
dsr611 Posted July 26, 2018 Posted July 26, 2018 Hazy headlights are a common problem on all vehicles with plastic headlights
waumo1 Posted July 26, 2018 Posted July 26, 2018 I did my 1998 truck headlights with the 3M kit that uses different grits of sandpaper and then polish in a drill. After the first sanding step they looked hopeless but by the time I was done they looked new. Still looked good several years later when I sold it.
Loco Diablo Posted July 26, 2018 Posted July 26, 2018 Bug spray? Just go buy the correct stuff at the auto parts store. Do it right whether it’s a beater or not.Sent from my iPhone using Tapatalk
Jsdirt Posted July 26, 2018 Posted July 26, 2018 Yeah, REPLACE the headlights, Loco! I paid $20 for the Sylvania stuff a couple years ago to do the neighbor's '06 Impala. In 6 months they looked like crap again. A whole lot of work and money for nothing. Ended up just buying a chinese set off eBay for $100 for the set - had to do some wiring (wires too short, lol), but 2 years later they still look brand new. His sits facing the sun all day long, every day. Bug spray is $5, and takes 30 seconds to do both lights. A no brainer to me ...
Doug_Scott Posted July 27, 2018 Posted July 27, 2018 4 hours ago, Loco Diablo said: Bug spray? Just go buy the correct stuff at the auto parts store. Do it right whether it’s a beater or not. Sent from my iPhone using Tapatalk The "right" way according to who? Both methods can cause damage to the surrounding body if not performed with care. The video gives the way to stop the deet from continuing to soften the lens, after it attempts to scare you off. If deet makes the lens so soft and sticky, does it pull any lint off the rag used, or any bits of paper towel?
Jsdirt Posted July 27, 2018 Posted July 27, 2018 I just used a paper towel - it slid right across the light, and made it look 100x better than it did. Nothing stuck. I can't see any way of damaging finish in the rain like the vid suggested, unless you toss a 5 gallon bucket of the stuff all over the grille area ...
Loco Diablo Posted July 28, 2018 Posted July 28, 2018 The "right" way according to who? Both methods can cause damage to the surrounding body if not performed with care. The video gives the way to stop the deet from continuing to soften the lens, after it attempts to scare you off. If deet makes the lens so soft and sticky, does it pull any lint off the rag used, or any bits of paper towel? By right way, I mean buy a product meant for this. I bought a turtle wax headlight restorer kit for like $5 at Walmart.. 3 step process, worked great.Sent from my iPhone using Tapatalk
