1 hour ago, wizard4878 said:
installed  gator roll up bed cover, center console organizer, and chrome/plastic gmc logo valve stem covers
Any chance you can post some pics of the gator roll up tonneau cover? And how do you like it so far?
So far its great,  I sprayed it with a high pressure washer from about 2 feet away and it didn't leak.  It's simple to install by yourself, you just have to be careful not to over tighten those aluminum clamps.  I will try to remember to get some pictures tomorrow
Picked up my ordered truck today, white tricoat, with  rc 2” level and nitto terra grappler g2 tires 275x65x20[emoji4] no rubbing issues 34” tall
I would like to see more pictures of your truck, want to do a 2 in lift and possibly keep the stock rims also.
Sent from my SM-G930V using Tapatalk
Here's the Gator roll-up...I like mine a lot, came from a Bak Flip on my previous truck and I like the looks of this one better.306b51da6a6edccce68002a19c292e02.jpgb03b53d53c3962c5ded577275578e2f5.jpg
mine sits on top of the rail rather than inside,  I'll post pics as after as the sun comes up
Any chance you share the link to where you got it? I like how flush it looks
My cell is 970-209-3098 text me and I will take more pics let me know what you want to see. Weylin
Sure thing, the price is the best part. [emoji41]
Gator ETX Soft Roll Up Truck Bed Tonneau Cover | 137245 | fits 2019 GMC Sierra/Chevy Silverado 1500 (New Body Style), 5.8' Bed | Made in the USA https://www.amazon.com/dp/B07J2T7DZC/ref=cm_sw_r_cp_apa_i_jDawDb9K8ZSVK
New wheels
20x10-25 tis 544bm
285x60x20 toyo open country RT
AT4 stock 2 in lift
1.5 level
Still had to cut[emoji31]
fd61d09d4f932eadfb9f86263b5eae53.jpg2e93c2e9d4be7bcb70d93188e7a0aad1.jpg7dd977fa51462d59c252b01022b16d70.jpg395b3d9b3d9bb0f39fad99e0542f5e8c.jpg
Sent from my SM-G965U using Tapatalk
  • Like 4
14 hours ago, gothp28 said:
New wheels
20x10-25 tis 544bm
AT4 stock 2 in lift
1.5 level
What did you use to paint your calipers?
On 3/10/2019 at 9:33 PM, Englshmn said:
Fabtech Trail Boss / AT4 4" lift
Method 305 NV 18x9 -12 4.5"
Toyo MT 35x12.5r18
Knew that area looked familiar, spent 20 years on the other side of that little bridge, in Pinellas County
Nice truck too, my fav color combo with the TB package.
Edited by CrankyYankee
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
