Holy sheet I just noticed it says home on the dash [emoji15] it knows where it is
Ryan B.
1 hour ago, RyanbabZ71 said:
Holy sheet I just noticed it says home on the dash emoji15.png it knows where it is
Ryan B.
LOL
Ryan B.
I didn't realize the Chevy gauges were so different than the GMC. Btw, that's your home screen. [emoji16]
11 hours ago, 14 Silvy said:
Where abouts in Frankfort?
West side in the meadows.  I drive a Cajun Red Custom Trailboss if you see it around.
19 hours ago, 2k19Sierra said:
Gm parts.com!
anyone happen to know the part # for silver mirror covers?
i see every colour mirror cap but the silver on the GMC accessories page...
Edited by 2k19Sierra
 He wakes up and says “daddy’s truck , drive “ , so we went riding through the corn fields today.  Good times
  • Like 10
haha go figure.. I guess chrome could work. Or paint em
I assume that’s because they don’t make a High Country in Silver Ice Metallic. If you look at the model line, the only truck that actually has factory painted mirror caps is the HC. And there’s no HC paint code for silver ice. ??
Its too bad bc I would love to color match mine too.
I guess wrapping it is the only/easiest option! 3M gloss white aluminum (color code G120) is almost a perfect match BTW. Looks really good.
Edited by Chance1025
I assume that’s because they don’t make a High Country in Silver Ice Metallic. If you look at the model line, the only truck that actually has factory painted mirror caps is the HC. And there’s no HC paint code for silver ice. [emoji1361]
Paint them. I had my door handles painted satin steel (original chrome) by the dealer they came out great
Ryan B.
Not exactly....The High Country is available in Northsky Blue Metallic and there hasn't been any Northsky mirror caps.  I've been looking for Northsky painted caps for my RST since the beginning and haven't seen them yet.
Same with satin steel
Sent from my iPad using Tapatalk Pro
That's cool I'm out in Farmdale I have a 18 Z71.532ec294e04d35b36719ac3a60731e4b.jpg
Sent from my SM-G955U using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
