MHPrior80 Posted October 22, 2018 Posted October 22, 2018 Has anyone come up with a way to disable just the auto headlights? I don’t want to turn off the DRLs and I know if I turn the headlight switch to the left it disables the DRLs. For some reason my 18 is so sensitive in the auto headlights. Going home today they headlights came on around 4:30pm. The sun was shining etc. No clue why they would just turn on. Anyways if anyone has come up with something and I’m just not seeing it let me know. Thanks.
BlueTopaz14 Posted October 22, 2018 Posted October 22, 2018 I know it’s possible to open up the switch and remove the little spring that makes it flip back to auto. Maybe the guy who did it will chime in to help you out. It’s pretty simple from what I remember Sent from my iPhone using Tapatalk
MHPrior80 Posted October 22, 2018 Author Posted October 22, 2018 Doesn’t that disable the DRLs though? I’m not looking for that. Just the auto headlights themselves
Black02Silverado Posted October 22, 2018 Posted October 22, 2018 There is a write-up on here about putting a resistor in the sensor on the dash to make it seem like there is light all the time so you would have to turn the lights on manually. I can't seem to find it.
Sierra706 Posted October 22, 2018 Posted October 22, 2018 Some members have taken apart that light sensor and removed some of the grease like substance inside. It was much less sensitive after. Sent from my iPhone using Tapatalk
MHPrior80 Posted October 22, 2018 Author Posted October 22, 2018 I just found the video for adding the resister, only question I have now is how do I get to the light sensor through the dash?
Sierra706 Posted October 22, 2018 Posted October 22, 2018 I just found the video for adding the resister, only question I have now is how do I get to the light sensor through the dash?Rip most of the dash offSent from my iPhone using Tapatalk
Darth_Vader Posted October 23, 2018 Posted October 23, 2018 Have to pull the A pillars off both sides and then the front trim by the windshield which the sensor sticks out of can be popped up from the sides.
Donstar Posted October 23, 2018 Posted October 23, 2018 Maybe your sensor is faulty. Your truck is covered under warranty and worth asking the question. I've had my truck for over 3 years and headlights turn on and off appropriately. Most vehicles now are produced with automatic exterior lighting. Those of us with our personal built-in light sensors who automatically reach for the light switch at dusk are becoming a rarity. For the benefit of others driving your vehicle in the future, I recommend keeping this feature active.
Ozer Posted October 23, 2018 Posted October 23, 2018 Its annoying for me as well, mine comes on in the parking garage, middle of the day. Not even the parking garage lights are on...
Maxsuperdog Posted October 23, 2018 Posted October 23, 2018 Has anyone just unplugged the sensor? I've modded my light switch so that I have to manually turn them on but the dash lights are also tied into the sensor and these are the ones that bother me with numerous switches at dusk.
Darth_Vader Posted October 24, 2018 Posted October 24, 2018 14 hours ago, Maxsuperdog said: Has anyone just unplugged the sensor? I've modded my light switch so that I have to manually turn them on but the dash lights are also tied into the sensor and these are the ones that bother me with numerous switches at dusk. If you have automatic climate control you don't want to unhook it as it also helps control the temp.
MHPrior80 Posted October 24, 2018 Author Posted October 24, 2018 Dang. So if I add the resistor to this it may not work for the auto temp then? It needs to be unplugged and the resistor in the plug
