good morning . I just changed over from my summer wheels.  back to stock for winter. the reset tool that I used to reprogram 18 inch fuel rims for summer driving .will not wake up the 17 inch stock tires. any suggestions the reset tool is a ,ateq purchased off amazon . it states that it is compatible with a 2016 Chevy Silverado. I would hate to have to buy another re programmer .
amazon web page states that it go's to 2013  my truck is a 2016. I bought the ateq reset activation tool $139.00 from amazon . it re learned my new fuel rims but not my stock. but it says that it will in the description on web page .
I have the Orange tool that I linked.  I got it from GM Special Tools under the EL-50448 number, and I've had it for 6 years.  I can use it on 2018 trucks at work here no issue.  Works on my 2016 Colorado too.
I bought this one for my '16, worked like a charm.  Just have to aim it in the right place, at the tire above the valve.
https://www.amazon.com/gp/product/B06XVR85N7/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
  • 4 months later...
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
