Black Friday Mods, What Are You Planning?
Mileguru
9 hours ago, Nasty said:
Looks good  i still havent decided wheather to go with maggie or lt4 charger.  Maggie is legal. But guys have been saying theyve been getting more out of the lt4 than the maggie even though its smaller.  And i think because its a "chevrolet part" i can get away with it smogging.
The Magnuson TVS1900 is CA smog legal for 2017 and below. I was the first person to get the CARB sticker for the 2017 GM trucks. To be smog legal, it just means that CARB has approved the stock Magnuson tune and the pulley size. Nasty lives up in NorCal, so he has to deal with this BS. Qwank is in NH, so he lives free or dies. Awesome purchase, Qwank. Congrats and have fun!!!
  • Replies 97
I have a smog guy.  And i dont have to smog the truck for 4 more years. But even though maggie is smog legal (so is whipple) i kind of want the lt4 because it fits with what im doing to the truck. Upgrading it with factory parts. So its stock but not stock
11 hours ago, qwank said:
I just ordered the SLP TVS1900 for $4,600 shipped.  I don't think I'll find any other complete forced induction kit for  less than this.
Care to share where you found this deal?
TPS Motorsports
On 11/17/2018 at 11:09 AM, Nasty said:
Didnt even know slp made one. Thats super cheap but its probably not smog legal :(
I just found this on another website, not sure if it's correct or not.  I suppose I can let you know when mine comes in if it has a CARB legal sticker.
DETAILS:
Horsepower gain: 165+
1900 2.3L TVS supercharger head unit
Highly effective air-to-water intercooling
Intake manifold ports are port-matched (designed into casting) to the cylinder head ports for greater air flow
5-bolt pulley mounting system stronger than 4-bolt system
Belt Drive System: Factory 6 rib
Fuel Pump Supplied: Not Required
Fuel Injectors Supplied
Computer/Ignition Mods.: SLP Developed and Custom PCM Calibration
The coolest charge air temperatures and largest power gains available
3 year/36,000 mile parts warranty
Easy and quick installation
50 State Legal CARB EO #D-187-24
System is 100% complete with OEM quality and appearance
DETAILS:
If it is id like a review. It is a tvs so thats good.  1 thing i dont understand is it says 1900 2.3.  1900is 1.9 and 2300 is 2.3
yeah, that's weird.  I didn't even notice that.  SLP did have both kits.  But they are both discontinued and the place I got mine from bought the rest of SLPs stock of 1900s.  I'll look around some more.
Can you do anything with the E0#? like is it a number just for this supecharger that can be referenced somewhere?
No clue. But i just looked up thr supercharger itself. They are now smog legal.  Buuuut.........tbey cost more than the whipple
not at the place I got mine from
That was a sale price. Im talking normal price because im not doing motor work yet.  Im changing out most of my suspension right now
oh, I see. They are discontinued though but that price until the end of November.  Not sure how many are left.  I haven't even gotten mine in yet, so who knows if it will even show up :lol:
Typically, to be CARB legal and get the EO sticker, you have to purchase the tune that the company sells. Whether or not you install this tune and run it is up to you. You can always pay a tuner for another tune.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
