Hey, I'm getting an aftermarket subwoofer setup. I would Like to get a button to turn the amp on and off. Either for the seat warmer position or the bank of buttons below. Does anyone have a site where I could buy one?
19 minutes ago, Nasty said:
Why do you want to turn the amp off?
Got kids. So I like to have the option to easily shut it off.
Why not just turn it all the way down.  Is this just a sub amp?
Getting a sub and an amp installed. I would like a button to just be able to kill the amp when I please. I've installed them in previous cars, but I've always done an aftermarket rocker switch. This time I'd like to do a switch that sticks with the stock deal.
Can i make a suggestion over running a switch?
2 minutes ago, Mlamp89 said:
Sure.
Run a pac lc1 knob.  Turn it all the way down when you dont want it on  and use it as a bass knob
Not a bad idea. Thanks, I'll look around for some good ways of setting one up to keep the looks clean.
Its super easy. I use them as a bass knob. Always have. Because of how they work.  Bass knobs that come with amps are junk. The pac lc1 actually cits voltage or increases voltage. Works a lot better and i personally think ot looks better than a toggle switch. Best of both worlds and i think theyre only 18 bucks
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
