Overloaded
Lou Summerall
I have a 2014 Silverado 1500 5.3L 3.42 rear and towing a 8600#travel trailer. After hitting the scales yesterday I found out I am way over weight. I know I should have bought a 2500 but it is to late for that. I was wondering if anyone had had there truck upgraded max tow package and how much. Can't afford a new truck plus wife loves this one. Any help would be greatly appreciated. My current towing capacity is 9600#. I am 1000# over on GCVW.
My friend tows a lot of weight with a 2011 1500 avalanche. He had to upgrade the trans cooler but you likely don’t need to do that unless your trans temps are hitting like 220 plus.
He did trans cooler, airbags, and a nice brake controller. He tows up to 15k lbs short distances and says it handles the weight fine.
airbags > whatever suspension the max tow has
1,000 lb over?  Is the 8,600 lb weight figure for the trailer loaded, or unloaded?  How many people in the vehicle?
I'm just curious where all the weight is coming from.
You already have a decent gear ratio, so that's not really a problem.
You can upgrade suspension & add air bags to make it feel more stable.
You can put on tires with a higher load rating.
The biggest thing that is limiting your ability to control a heavy load is the brakes, definitely make sure the trailer brakes and controller are set-up and working properly. But you could try to upgrade the truck's brakes as well.
But, jeeze, please be careful pulling that heavy thing around. I hope I don't encounter you on the road.
Trailer loaded weight. We were not able to weigh prior to leaving.
The problem is no matter what you do to “beef up” the truck to handle the weight you can’t change the factory tow rating numbers. Even if the dealer was to install all the “max tow” equipment they can’t change the sticker in the door. Can the truck be made to handle more weight of course but it won’t change the fact that your illegally exceeding the limitations of the truck and if heaven forbid your in any kind accident whether it’s your fault or not or if you get pulled over and weighted by a DOT officer. IMO the problem isn’t the weight it’s the liability risk your placing on yourself and your family you have to consider. It would be quite the burden to have a insurance claim totally denied or be told to leave your trailer on the side of the road a 1000 miles from home if you want to continue on your trip...
Truck ain't lawful to tow that much no matter what you do.  Can you beef up the truck to handle it?  Easily.  Can it be re-certified for the additional capacity the mods add?  IDK!
Happy Thanksgiving!
At what point after this accident do they determine if you were, or where not over your weight ratings?
They'd figure it out during the cops accident report lol
How?  It's easy to check the stickers on the trailer and tow vehicle, but short of putting everything (and everybody) on a scale, there's no way to know the weight of the contents.
According to the ownser manual if I swap the rear gear to 373 I would be 1000 # under.
A mess like that is loaded in a truck for disposal. The truck is weighed so they know how much to charge to dispose of it.
Really quite easy.
Yes, but that doesn't change the certified limits of the truck. If you look up your vin # you can find the info from the build that GM used to certify the vehicle.
You need to find where the extra weight is, the trailer or the truck. Are you running with full water tanks or things like that?
    liddlera
    liddlera
  • Who's Online   5 Members, 1 Anonymous, 355 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
