Hi all,
I hope I’m not the only one frustrated with this issue. For a few months, I have had issues with my back up camera being very fuzzy/grainy, which is almost unusable at night. I took it in to my local dealership and found out that there is a technical bulletin for this issue basically saying that if any 12 volt accessory plugged in, it is causing the issue. In my case, it’s a dash cam that is on all the time. Basically I was told that there is nothing they can do and I need to unplug my dash camera to have a useable backup camera. For a 2018 Sierra, I would expect there wouldn’t be these issues as I didn’t have them in my 2014. Has anyone figured out a workaround to still allow the 12 volt accessory to be plugged in but not cause the grainy/fuzzy output?
PIT5552B is the bulletin.
Hardwire you’re dash cam in. That’s what I did with mine. It turned on every time the truck starts and I have to manually turn it off when I get out of it for the day.
  • Confused 1
My 2016 has always been fuzzy with no 12v accessories plugged in.  Even after meticulously cleaning the external lens.
4 hours ago, 1SLOW1500 said:
Oh there is a fix. We have seen it and have it done. Keep searching.
Sent from my SM-N950U using Tapatalk
Seems I can order the 2016 OEM assembly for about $110 which includes the lens and cable which connects under the bed to a connector.  Do you know if the cable plugs into the lens so I can just replace the lens from the kit without fishing the wire?
https://www.gmpartsgarage.com/oem-parts/gm-rear-camera-84062896?c=Zz1lbGVjdHJpY2FsJnM9cGFya2luZy1haWQmbD0xJm49U2VhcmNoIFJlc3VsdHMmYT1jaGV2cm9sZXQmbz1zaWx2ZXJhZG8tMTUwMCZ5PTIwMTYmdD1oaWdoLWNvdW50cnkmZT01LTNsLXY4LWdhcw%3D%3D
Year of the truck depends on what camera you buy because theres another plug with the camera that powers the locking tailgate
I’ve searched and haven’t found a fix. If you have more information, I’d appreciate it.
  • Thanks 1
If the power wire draw is to high and is causing the camera to flicker you have some options.
new power source on the 12v acc. cut wire and add relay. It will isolate the feed and reduce the draw.
add another power the the camera circuit.
you could even temporary tap the wire over for a day and see if the "patch" fixes it.
as far as your dash cam. I recommend Rap wire in drive fuse box. fuse it to the real draw. If you want constant power kick panel fuse box again fuse it.
As I tell everyone. ask dealer for the FULL print out of all codes reported. It will surprise you the history codes. They can show low voltage and and even fault circuits.
The part I gave the URL for is for my 2016 High Country.
What I want to know is if I can replace the camera without having to re-snake the wire.  Is there a plug on the lens end so that I can just swap out the lens which I believe may be the cause of my blurry image.  It works fine, except for the blurry image.
No you have to change the whole thing. Its super easy. Should take 5 minutes. I added backup cam in my truck
  • 2 months later...
I got a 2018 Sierra , after I installed the after market LED backup bulb, the camera would glitches.  I brought it to the dealership and they told me it was the LED bulb, so i took it off and put the original incandescent bulbs back and it still glitches sometimes. Listen up GMC!
  • 2 years later...
So. As of for me. I replaced headlight low beam light bulbs half a year ago and that when this blurry screen appeared. I was driving with blurry screen for a half a year. Took it to the dealer and boom! They couldn’t do anything and $1800 later I picked it up from them. I read this thread and remembered about light bulbs. Then I put it in reverse and ... manually shut the lights off as they are always on as day running lights. My screen became hd quality lol. You are welcome everyone!!!
Edited by Tymur
  • 7 months later...
I've unpluggedmy power port phone block and it made no difference. Next step is to unplug and clean connections. If no improvement I'll install an aftermarket.
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 296 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
