GM is aware of this problem with failing injectors.
GM will do an assist for labor only and you pay for GM dealerships overpriced parts.
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
