A few weeks ago, while driving my 2011 GMC Yukon Denali (with 185,000 miles), the vehicle suddenly began making an obnoxious noise. There were no check engine lights, but the engine sounded rough. I later discovered that it was an AFM (Active Fuel Management) lifter failure on Cylinder 6. I was able to drive the vehicle home, and based on recommendations to avoid further damage, I parked it and began researching the issue.
With the help of a friend, I started diagnosing the problem. The first step was to confirm lifter failure by removing the valve cover. We identified the issue on the exhaust valve of Cylinder 6 its rocker arm was barely moving, indicating a lifter problem.
I tried the Marvel Mystery Oil method, following instructions to let the engine idle and drive it briefly, but after several attempts, it didn’t help. I realized that continuing to run the engine in this condition could cause more serious damage, so I decided to move forward with a proper repair. That meant rebuilding the head and replacing the lifters with new ones.
I proceeded with head removal steps by taking out the exhaust, intake, and finally the head where the problem was present. After removing the head and removing the lifter trays i laid out the lifters and confirmed one of them was soo stuck that it prevented the roller from moving:
I decided to proceed with using the AFM (Active Fuel Management) version of the lifters to repair the issue. I wasn’t entirely sure what kind of emissions or smog-related problems I might run into with California regulations during the next registration cycle, so I chose the path of least resistance and stuck with the original AFM setup.
The repair involved the following:
  • 4 brand-new OEM AFM lifters
  • 4 new standard lifters
  • New head gasket
  • New exhaust gasket and bolts
  • New head bolts
  • New valve cover gasket
  • New valve stem seals
  • Cylinder head machined (0.004” taken off) and deep cleaned
  • New dowel pins for head alignment
  • New lifter guide trays
  • New valley cover (valve lifter oil manifold) with new solenoids
  • New oil pressure sensor
  • Fuel injectors cleaned, flow-tested for spray pattern and resistance, with new O-rings installed
  • New intake manifold gasket
  • New ignition coils, coil wires, and spark plugs
All components were properly torqued according to specifications, including the head bolts which were torqued in three stages.
Now after all that I am getting the consistent Misfire on Cylinder 6, this is the Cylinder that had the original Lifter failure:
I tested the ignition coils and fuel injectors which are working as expected. I did compression test of the newly installed head getting the following readings (around ~180 for all 4 cylinders on rebuilt head):
20250526_160256.thumb.jpg.0d3af186b2db7bdb9847f9d9733736cd.jpg20250526_151126.thumb.jpg.901ae1e47ce952747d4d1bf70c3fe136.jpg20250526_150247.thumb.jpg.888a68621ccdac1f466833b74d1633f1.jpg
I was told that if the cylinder head wasn’t installed correctly, I wouldn’t get proper compression. At this point, I’m not sure what the root issue could be. The only thing that comes to mind is a possible problem with the wiring harness for the ignition coils or fuel injectors but that seems unlikely and a bit strange.
Has anyone experienced something similar or have any ideas on what the issue might be, given everything I’ve done so far?
If I can’t get this resolved, my next step will likely be a full rebuild and an AFM delete I'm ready to get rid of that system entirely and make this engine truly reliable again.
Thanks in advance for any help or input!
The cylinder head appeared to be in good condition, no warping or visible damage, just the typical carbon buildup. The valves held pressure and moved smoothly during inspection. I did make a minor scratch near the dowel guide while removing the head, but the machine shop corrected it. They fully inspected the head and confirmed it was in solid condition.
The camshaft was also in good shape. I didn’t allow the stuck lifter to run long enough to cause damage, and there were no scratches or grooves visible. I inspected the cam using a mechanic’s inspection camera while slowly and manually cranking the engine, and everything looked normal. There was also no sign of metal shavings or glitter in the oil or engine bay.
Edited by DIY Mechanic Mike
Yesterday, I performed another round of compression tests. I removed all the spark plugs and pulled the two fuel injector fuses so the engine would only crank without firing. I also connected a battery charger to maintain voltage and ensure consistent cranking.
I tested all cylinders, and each one showed 210 PSI+ (some 235 PSI for some reason). However, Cylinder 6 behaved differently: while it initially built up to 210 PSI, it suddenly stopped compressing during continuous cranking and drop to zero. That indicated a problem with one of the valves on Cylinder 6.
Next, I removed the valve cover and observed the valvetrain while cranking the engine again. This time, I could clearly see that one of the valves on Cylinder 6 stopped moving entirely after a few cranks and stayed inactive. This valve has a new AFM lifter installed, I replaced all lifters on this cam with new ones during the rebuild.
I’ve been told this could be due to either a faulty solenoid in the valve valley cover or a bad OEM AFM lifter. However, i replaced the solenoid and I have new OEM AFM Lifter. I've even heard that GM's expensive original AFM lifters can fail unexpectedly, sometimes with very low mileage. What’s confusing is that this time the lifter isn’t physically stuck or making noise, rather, it seems to deactivate suddenly and causes the valve to stop moving entirely while cranking.
I’m preparing to remove the head again so I can pull the AFM lifter (probably all of the AFM lifters i bought since cant trust them now) and return it to NAPA Auto Parts. I’m confident everything was installed correctly and have verified that through multiple tests. I’ve also replaced several components, some of which were likely still functional, simply because it made sense during the diagnostic process and as a best practice.
This has turned into an expensive investigation (but less expensive than taking to mechanic), but with the flawed design of the AFM system, there’s no straightforward way to troubleshoot these issues. I’ve even been told that professional mechanics face the same headaches with these AFM-equipped engines. In some cases, they end up processing multiple warranty claims within a short period to replace the same faulty lifters.
I’ll need a new head gasket and a new set of head bolts. I don’t trust reusing the (new) used bolts, as they stretch during the torque process, which is especially concerning with aluminum block engines. It's not worth the risk.
Any recommendations before I proceed with the expensive process again are appreciated at the risk the new lifter will still deactivate, what else could be causing the lifter to go into deactivation when its visible active for short period of time maintaining pressure, I was told its when oil goes into the lifter during cranking and possible the spring on the lifter is not up to spec then activates which indicates a defective lifter. I don't know!
The issue has been resolved, and the engine is now running well.
The problem was due to a single lifter that I had installed new into cylinder 6, its alignment was off by a few degrees and not properly seated into the designated grooves of the lifter tray. My Journey of fixing this thing is finally over until next time. Hopefully this will be useful for someone while I was also looking for some guidance myself yet figured it out through the tedious and painful process of taking this thing apart and putting back together 3 times.
For reference, here is an example of properly aligned lifters in a lifter tray:
FYI: You can test lifter installation with just the cylinder head installed, including rocker arms and pushrods, but without the exhaust manifold or spark plugs.
I temporarily installed the intake manifold only to connect the fuel line. There is no need to bolt it down, just place it in position. Although the fuel injectors are unplugged and their fuses removed, the fuel pump will still run during cranking and pressurize the fuel line. The intake helps contain any potential fuel and prevents it from spraying everywhere.
The engine was also drained of coolant, and there is no need to refill it just for cranking during these tests.
I used a battery charger to maintain power during cranking since the engine is not running and it is important to keep the battery healthy.
With this setup, I was able to observe the lifters and perform a compression test on each cylinder to confirm the head was installed correctly.
This method saves time and helps avoid the extra work of fully reassembling the engine only to find an issue that could have been caught much earlier in the process.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
