2016 2500 needs softer suspension
Jack Horn
2016 LT 2500, ecab, 4x4, 8' bed and air bags..  Pull 13K lb 5th wheel camper 3-6 times per year.  I would really like a 1500 but camper requires 2500.  Got a 2017 1500 loaner once and loved it.  Is there a way I can remove rear springs and add 1500 springs and possibly a 3500 overload spring when it squats a little.  This truck is too rough riding for retired old guy; but, still need it for camper.  Not into a temp fix of lowering tire pressure.  BTW, I've got over 1 1/2 million miles of GMs; mostly diesels so trucks aren't new to me; getting old is and it sucks.
Thanks for any/all opinions
Jack
CO
I don't think there is any way to make a HD ride like a LD.
No light duty truck is going to be able to handle 13K.
Sent from my SM-G965U using Tapatalk
Maybe more than you want to spend or do, you are a old man...HAHAH
But a new full rear suspension, with Lower control arms rear axle mounted 2500 bags, shocks and a pan or wish bone. That would let you do anything and also tow more weight, ride better than a caddy. If the check book can handle it you can have auto ride. A sensor that adds and removes air as it sees need. all you do is drive.
New, upgraded shocks and 3-400lbs in the bed when you're not towing?
I put about 150lbs in the back of my 1500, behind the rear wheel wells and it helped a lot with the highway ride.  I'd think a 2500 would need more.  Airbags aren't helping either.
What kind and size tire do you have?
I had a 2500 HD Denali, and lowering the rear air pressure did help a lot, and was free.
I’d give these guys a call and explain the situation to them and see if they can steer you in the right direction. Their website is a little over the top kinda like a lot of their builds but this company was started years ago by a farmer with a bad back and a Dodge Cummins. Daily driver, ag, and commercial is still their bread and butter.
https://kelderman.com/
You could certainly get a custom rear leaf pack and adjustable shocks to tailor your truck to your usage.
Or, you could get a tiny trailer, and tow it behind almost anything.  :D
Not sure what size wheel you have. I added Fox shocks and went to a 17" wheel wrapped in falken AT3. Made a huge difference. Doesn't handle car like, but I didn't buy a truck for the handling. anything with 20s and HD suspension is gonna be rough
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
