Adding power adjustable pedals?
I did a search on here and a search on google that yielded just a little bit of information, but nothing solid. Has anyone figured out how to swap in the power adjustable pedals using OEM parts yet? My truck is a 16 model single cab LT package. Granted I am 6'3" (I know, I know shouldnt have bought a single cab) and I love everything about the truck other than the position of the pedals. Seems like my previous 03, 07 Classic, and 08 single cabs were a lot more comfortable in that department. It is not my daily driver by any means, so it is something I can live with. I would prefer to complete the swap using all OEM parts.
My guess is that everyone who has them used them only once. Maybe a deal for two different drivers but otherwise use the seat adjustments and find something better to spend your $$$ on.
This. 100% useless option on this truck. On my Escalade EXT the brake pedal would sometimes squeak unless I ran the power pedals up and down a few times...probably will happen one day in this truck.
The power pedals are part of the memory package so I doubt they can be added after the fact without adding some other stuff as well.
Here’s another thread where somebody asked something similar
if Phil is correct (as I’m sure he is) and the power for the pedals doesn’t have to go though the BCM I would think this would be a doable project with the understanding that a custom harness and/or contols may be needed as long as the pedal assembly it a direct bolt in. I have found out to add the power passenger seat (non memory) to my LT as long as the seat harness has the pins for power & ground it’s a simple plug & play (since I don’t have memory) but even if the pins aren’t there for power & ground I only need to provide the seat with power & ground to work since it’s not powered though the BCM anyway. I would suspect the same is true of the pedals if your already wired for them & have the factory pedal relays. I’m sure if you made contact with Phil aka pgamboa he will know for sure as he seems to have about the most knowledge of anyone on these pedals outside of GM.
