The bose system sounds to peaky. Like the amp is trying to work to hard. And it not being the best amp thered a lot of distorsion. Iam a sound quality competitor. Ive done this for years and years
Im not saying youre wrong. But ill put money on on my non bose vs the wifes bose i bet if i were to bring both to an iasca event my LT would score higher
Less distorion and more balanced
So your non bose non modified would score better than the bose?
Hmmm interesting
Hmmm interesting
Right now i think so. It sounds much more balanced and less distorted
  • Sad 1
3 hours ago, ford5of5 said:
Here's a few pics of my setup.
looks good ...
How did you get this on the screen? I just installed one of these in my truck and I like that launcher. Also do you use waze? If so have you been having trouble with it at all on ur unit?
Lectrician7, that's the Agama car launcher. It's on the Google Play store. https://play.google.com/store/apps/details?id=altergames.carlauncher  The logo in the middle can be several things from a compass to a clock and even an info center for other apps. I had to change the theme and colors a little to make it look like that but it was real easy. To be 100% clear, neither this launcher or any other launcher I've tried on my device works correctly.
I've never used Waze. I can tell you that the Google maps that ships with the device works fine. The problems start when you upgrade the old Maps and the new Maps will not scale correctly. It works but the upper green bar is way bigger than it should be. I use the default Here nav app and it so far it works great.
Did your unit come in a box marketed as a Phoeinx device? Is it the fast boot 7.1 model? There are only 2 or 3 manufacturers and many, many sellers. Some of them come with android 4 and others android 7.
***READ THIS PART***
My unit has become useless in the last week. The lag times on the volume are getting to be around 30 seconds. I had this issue when I first installed the unit. I pulled it out and THOUGHT the issue was caused by a loose wire connector. The climate control lags too but only on the display changes; for actual function there is no lag.  About a week ago the issues came back. I checked the wires and they are all tight. Another issue is that the upper left climate button doesn't work anymore and it seems like the second button down is starting to have an issue. Yet another issue, is that the device will not release audio focus from the Console. So what that means is when I switch from Console to Music the radio continues to play.
An issue I had from the start is that when in Console mode the factory emulated screen is off center. The seller told me I had to run through all the parameters in one of the menus and find the right one. I've been through that twice now. The seller isn't terrible helpful, so far. Their engineers have been on vacation for the last few weeks. I MIGHT hear something from them on Monday.
Are you having issues with your unit? Is your truck I03? Please let me know. Are your issues only with Waze? At this point, I can't decide if I want to push for an exchange for another unit or a total refund. I'm not sure how far I'll get with either one.
Edited by ford5of5
That's a whole bunch of issues,   go for an exchange ASAP, if the next unit doesn't do well just get a refund and forget this you're going to be plagued with problems when the thing gets old instead of just out of the box.
Thanks for letting me know what launcher that was.What version is the google maps are you running? Mine came updated to a version that has the HUGE green bar. If yours doesn't have the green bar I'll install it and not let it auto update. The issues I had with Waze was no audio commands ( I fixed this somehow) and now the audio player won't connect to TuneIn Radio, iHeartRadio, and Pandora, but I thin k it's an issue Waze needs to correct in an update.
I think (but I'm not sure) it came marked as a Phoenix product. It is a fast boot version with 7.1 on it. I did do the update for it that phoenix had posted in their drop box account. They have a video on their YouTube channel that explains it and posts a link to the file. I've heard that some launchers cause them to slow waaayyy down, so maybe that's the issue? Mine came with the original screen portion way to the right but the touch wasn't offset with it. I had to adjust the parameters on mine and 7 works perfectly. I believe my truck came with I06. It had the 8" screen that has Bluetooth and factory NAV since it's a loaded SLT.
The only other issue I have is, in order for it to connect to WiFi I need to go to the WiFi settings page then it connects to my phones hotspot, but it won't automatically connect until I do that. These radios are clearly not a simply plug it in and go kinda thing, they require some setup and work.
Lectrician, sounds like you already have the upgraded Maps. The version mine comes with still has the robotic voice but works well. When I update it to get the modern voice, then I get the green bar. Other than the green bar taking up a bunch of space and the search bar being a few inches too low Maps technically works. I've had occasional issues with voice guidance on Here and Maps. I think it comes down to the audio focus of the unit. I'll give Wazes a shot and report back what happens. I've heard good things about it from others but never tried it cause I was a big fan of Scout and had Maps as a fallback.
I bought my unit from Kirinavi, a reseller, but it's a Phoeinix 7.1 fast boot. Kirinavi's engineers have been trying to help but there's the language barrier. They told me to go Pheoinex for an exchange; I'll reach out to them later today. There was a 30 day money back guarantee on the unit but I'm way past that. I can deal with software issues but the climate control buttons not working is a total deal breaker and now I want an exchange. I did the Phoeinix MCU upgrade but it did not fix my off center issue.
I've tried 3 launchers now. So that's probably why I'm having so many issue with lagging. Have you checked out XDA Developers? It's an Android modding site. There are people out there ironing the bugs out of these units. There is a way to reset audio focus and to reassign the top bar icons. Unfortunately, a lot of the info is from a Russian site and I only got a C in high school programming so I don't know how far I'll go down that avenue.
I did have Google voice working but it was SLOW! It allowed me to make calls, search the net and choose music through voice commands.
I thought I was all set when I found the Agama launcher because it put EVERYTHING on a single page. I have the same issue with wi-fi but only when the device reboots. I have mine set to stay on for 48 hours.
You know what really stinks about this entire situation for me? I'm 43. I've been careful with money most of my life. I'm not even close to being well off, but if anything goes sideways I'll be ok for awhile. I could have went the MVI I06 route or bought a highly optioned truck, but I'm still stuck in that "be careful with your money" mindset. I guess this is what happens when you try to save a buck when you don't have to.
On 12/20/2018 at 5:40 PM, Penguin VII said:
Do not get this unit. I have no experience with it directly but a handful of reasons why:
  • The tech is based off a cheap consumer android tablet. Generally these tablets have degrading performance over time much more severely than the OEM tech. You won't notice this the first few weeks but you will most surely notice after a few months.
  • You really don't want all your controls on a screen. It may seem nice because you can use the extra space but it's going to be annoying over time when you try and adjust the A/C and can't get it right because its a touch screen. This will be more painful once the tablet starts to slow down.
  • Boot time is horrendous on these things from what I've read.
  • The volume and fan are switched, which is annoying.
Good call on the volume and fan knobs, I noticed something looked off but couldn't pin point what exactly. lol .
@lectrician7, I just tried Waze. WOW, it's pretty great. Thanks for giving me a reason to try it. On my unit, I can only get voice directions on any nav app if I'm using a music player. When I use Console, it will not release audio focus for the nav app. I've had good luck with using split screen for nav and music players but it takes some practice to do it while driving.
As a side note, the lag issues went away. A reboot may have fixed the issues. I got a funny feeling that they'll be back.
@g2full
-Most android head units are consumer grade and that's reflected in the price. A lot of what you're buying with these particular units is the system integration and the huge screen. These units are lack-luster but do not judge all Android head units by this one. Some are better than others. For the cost, I wish I invested in one of the smaller, cheaper units with an independent stereo attached that did not integrate with the GM systems. The big issue you run into with Android based units is that the bezels never fit perfectly without a little modification.
-Most of the climate controls are not on the screen, on these units. We have hard buttons and a knob. Lag time is with the displaying of the climate settings change, not the control of it. Ironically, this is reversed with the volume controls. It will lag in turning it up or down in both control and display. As discussed, this may have been caused by using alternate launchers.
-Boot time is horrendous at about 40-50 seconds, I can confirm this. The unit will only need to be rebooted if your vehicle hasn't been started in 2 days.
-The volume switch doesn't bother me and, I swear I'm not sticking up the guy that came up with idea because I think it's silly too but, the heat knob on the left is working out for me very well. I always end up playing with it a lot when on a long trip. I also play with the home thermostat a lot too, LOL. I was planning on using a remote like the one in the pic below. Now, I may have a chance to get my steering wheel controls to work. Either way, I will not be trying to get any remotes to work until I have a functional head unit.
***At this time, I do not recommend these units to anyone. I purchased mine because I'm a tech geek and can handle playing around with them. Also, I can technically afford the hit should I turn the unit into a brick or maybe, a clay pigeon. I have a WT with I03. My opinion for people looking to upgrade would be to look into the Alpine 110x/i209  or an MVI upgrade. If you're on a budget or like me, just plain cheap, then a $200-300 Joying unit would be an ok choice.
I'm not sure you tried this stuff yet, but if I were you I would check out the Phoenix YouTube channel. They have videos that can help with everyone of these steps I would take.
1. Verify you do in fact have 7.1 installed, just cause it says it doesn't mean it is. Some of these Chinese manufacturers have been know to spoof the specs on the units.
2. Do the PX3 update, I've seen in many places that after the update parameter 7 should be selected.
3.Verify you have the right vehicle selected. There are many setups in our trucks and some have auto ac some don't, some have steering wheel controls some don't etc. This will make sure your ac settings are what they should be.
Also I think when these units were setup fir the 14-18 trucks they did it with the vehicles that have the radio controls on the steering wheel and the the color display in the gauge cluster in mind. Having these options is really helpful for making sure the right output is selected sometimes. If step 3 isn't done right the android tablet may not have some of the controls displayed or programmed properly. Like I said if you already did this stuff sorry wasting you time.
I just got google voice working today, so far so good. Fingers crossed it doesn't get slow. No I haven't checked out  XDA Developers yet, I will. What did you search for to find the threads about these units. One thing I wish could be done is hide the icon bar at the top. With the Agama launcher I don't need it and on some apps it blocks the top part of the screen like Pandora where I can't access the top bar for searching and settings. Another thing that would be nice is like you mentioned having the NAV apps interrupt the actual radio like my phone does over Bluetooth. I was able to fix my wifi issue I think, thanks to you. Mine was not set to 48 hours it was the lowest one (can't remember what that is now though). I changed it and it seems to be functioning right now. If yours is soooo slow maybe try a factory reset and start over without installing the launchers you don't use.
On 12/23/2018 at 3:40 PM, Nasty said:
Bose and sound quality should not be in the same sentence
Get some Focal speakers and a good amp and you're set.  Best speakers I have ever owned.
Why focal?
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
