I saw these advertised when I first purchased the truck in October now I can’t seem to find them anywhere available for purchase
Anyone know what happened
have you check with your dealership ??? also check out www.cheapestgmparts.com . & www. gmpartscenter.net . they both list them
Many months ago I pointed out to the GM folks the design completely hid all of the tie downs in the bed ....
They were removed a few weeks later ...
While I doubt I really had any affect, I'll take credit.  :thumbs:
Thanks I should have been more specific I’m looking for the multi pro tailgate part number 84542684
Looks like the driver side storage box may interfere with the grab handle for multi pro
I really like the styling and location of these boxes probably make the switch in the spring from traditional toolbox
Can’t find the multi pro style online anywhere
e526c959ae578ab4ab71d5592d52d7ae.jpg8f6341efd21dd7efdc440c5313a40acf.jpg2afe17885a4914b2b6bf13d00ad0848d.jpg009966f68ab79bd365820df017b50658.jpg
are the boxes pictured in the thread immediately above this one the GM boxes which you're unable to source?  I like them but unsure if they're a GM or aftermarket box?
They are gm accessories
The ones pictured are for a non-multi pro tailgate
20 minutes ago, steve841 said:
They're just a swing case. Made by UnderCover. Just put one in my truck yesterday actually.
https://www.undercoverinfo.com/p-37122-undercover-swingcase.html
Oh sweet ..
How does it mount?  Their video wasnt very explicit on the mounting.
Also, does it stay put when driving?  Dont see any mechanism to hold it in place from the video.
FORGET IT ..just read the install guide.  I'm not drilling my bed.
Edited by steve841
Still no news on the GM side mounted bed storage?  Seems odd since they were a big hit at the truck reveal.
