2018 Silverado 400 miles 38% oil life
buckeyeguy142
6 minutes ago, buckeyeguy142 said:
Thats why i was concerned not rest only 400 miles is a 2018 and oil life is 38% how can that be possible, would have read 98% if reset so somehow this is true, can't be the mileage can't be just sitting on the lot, what would cause this ?
Deception
  • Replies 48
10 hours ago, qwank said:
What's even more confusing is I don't believe it says anything about time in the owner's manual, But I have confirmed this with GM tech assist after The first one I saw at 0%
Sure it mentions time.
(Although I always though the reason for the time note was the algorithm not taking time into consideration
This is the 2018 manual, but others are similar:
Engine Oil Change
When the CHANGE ENGINE OIL SOON message displays, have the engine oil and filter changed within the next 1 000 km/600 mi. If driven under the best conditions, the engine oil life system may not indicate the need for vehicle service for up to a year. The engine oil and filter must be changed at least once a year and the oil life system must be reset. Your trained dealer technician can perform this work.
If the engine oil life system is reset accidentally, service the vehicle within 5 000 km/3,000 mi since the last service. Reset the oil life system when the oil is changed.
See Engine Oil Life System 0 340
On a new one, it was probably never properly reset when it was built/tested.
Engine Oil Change
If you go to the page that says "see engine oil life system" it explains what the algorithm uses, but doesn't mention time there.
My last oil change was on 5-20-18, I've only put 340 miles on to date and I'm at 95%.
