Lowering???
Chevy B
I have a 2018 Silverado 2wd, I’m wanting to lower the truck just a bit my question is lower the rear 3” only, or should I go with a combo drop like 2-3, 2-4, 3-4, 3-5! I don’t want a huge drop just something to look better then stock. And what ever drop I go with do I get new shocks for a lowered truck or just stock shocks!!!!!! I’m blowing my head up trying to figure out which way to go! I need help
3/5 if its a crew cab.  People make a huge desl about lowering    and its not a deal at all.   Jusr have to do it
It is a crew cab, 3-5 would be a good way to go! What’s the best kit you would do for a smooth ride?
What nasty said. 3-5 here but I have 24". I have the bell tech kit that is adjustable and any kit that part number ends in sp has shocks. Rides great. I have a bag to help it is NOT needed but again i have huge wheels no overload leaf and need to tow. What to say I paid 800ish for it. Buy the camber cam platea also it's worth it and cheaper now then down the road. Enjoyd76487b59ef24681be9fc99075ce62b9.jpg
  • 1 month later...
I went with the Belltech kit and went 3-5 on my reg cab. I think the ride is a little rougher in the back with the Belltech shocks so I am looking for a replacement shock.
What shocks do you have
I have the Belltech sports. Which Viking shocks? Never heard of them.
Belltech sp is to stiff for a regular cab
I looked at the Vikings and they be a little more than I need for my DD. Anyone else have any recommendations?
Why are they more than you need
For a daily driver that will never see the track,  I don't need that much shock. Just looking for a little softer ride.
Mine wont ever see a track and i have qa1 single adjustables.  Ill be switching to viking double adjuatables soon.   They aren't "track shocks" but if it makes the ride better for something you drive everyday then i dont see why nothing
Which QA1s do you have?
Pretty sure the st709 but you have to do a little grinding on the mount. Just shave off an 1/8th so the shock body doesnt make contact. But im lowered so that number would be to short
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
