Weird noise
Does anybody experience the same problem , or has experienced this in the past. I recently just bought this vehicle no check engine lights or anything. The sound came about when it rained the night prior to the sound, drove the truck somewhere and parked for a while. Walking back I heard a weird sound didn’t know what it was, it was easily heard from 40 feet away found out it was coming from my truck. The truck wasn’t even turned on, just somehow made a lot of noise and wasn’t able to locate the noise.
1FC9C53E-6FF6-43F0-A072-4D38169A2F52.MOV
What is the vehicle?
Electric fan? I know it can run with car off and locked in some cases, and if there is a bearing going bad or something caught in it.... Just a guess on listening.
Sent from my SM-G960U using Tapatalk
You think it could be a catalytic converter, had a issue with one and they got it “fixed” but it the sound only happened for a couple hours and stop and so far since then nothing.
    • The Germans basically didn't make the list. There aren't a lot of shade-tree mechanics who work on them in general. At some point the economic equation of keeping a car alive favors junking it. Anecdote/experience tells me this is the case versus actual bad engines/engineering. Not that there isn't any, but there are definitely notable excellent examples. The 2.0 diesels will go forever and ever if one keeps the car around it running. The 2.0 gas cars eventually wear out their turbos but the block below it is usually still solid as a rock. BMW inline 6's same thing. Mercedes diesels of yesteryear, not uncommon to see 250k out of those engines, easy.     Link to the synopsis of the study: https://www.iseecars.com/longest-lasting-cars-study
    • 0w20 is recommended in the Sequoia. 0w16 in the Highlander Hybrid.   I think you make a compelling case for both the quality and frequency of maintenance but I wouldn't go so far as to plot a linear relationship between longevity and oil weight 😉   The list is interesting and leaves me with some questions. The Silverado 1500 is 12.9% likely while the GMC Sierra 1500 is only 10.8% likely. Arguably, they're the same truck, so other factors must be influencing the outcome.   The Honda Odyssey ranks #12 at 13% likely. Great. Rest assured we'll never stop hearing about the dang thing LOL.   There's a bit of a spread between the 4Runner (32.9%) and Tacoma (25.3%). Both overlap on the same 4.0 for many years although the Tacoma used a 3.5 for the last 10-12ish. I wonder if that's related to use-case or if it's suggesting the 3.5 isn't quite as up to the task, or maybe something else fails mechanically.   Ram at 3.5% overall likely, but the Ram 3500 holds the top spot on the Heavy Duty Models at 39.7%. One might say the Cummins is a ringer and provides an unfair advantage. I don't think it's fair/accurate to pit the GM Fullsize 1500's in a list with HD's which are basically medium-duty wearing a 3500 badge.   The Tahoe and Suburban hold spots #15 and #8, respectively, on the longest lasting SUV's list. What's the difference? One's got a shorter butt, unless they're also counting the 2500/3500 Suburbans in those numbers.   The GMC Canyon gets a 1.4% increase over its twin brother Colorado. Why, because it's prettier?   SO many questions...
    • Have the aftermarket system removed an re-test.  Its pretty much the only way to know if there is still an issue that is the truck and not from that.
    • Yeah they all have break in procedures I completely ignored in the past. During tests drives I would test them out. It seems today they’re sensitive so it’s probably a good idea to follow the procedure. The other would be changing the oil more frequently in the beginning.
    • Thanks for not getting back to share your findings...  🙄
