Which GMT-800 to buy
In the market for a GMT-800 5.3. Will be used for towing my race car mainly, but also on "regular" trips. Do any years seem to be the best, or is pretty much any 99-06/07 good?
I have a 2002 5.3 with max tow.
If you plan on doing any towing id suggest a 1500HD with the 6.0 or a 2500HD
My opinion, year won’t matter much as condition of the veh you buy.  I’d take an 99 with a rebuilt transmission over a 2007 beater
towing will be an 16ft open trailer, 4-5k lbs. That shouldn't be an issue for a 5.3, right?
The 1500HD with 6.0 was rock!  Love those models....2500's too!  They have their quarks and known cheap areas...engine and drivetrain not one of them.
Had a 2004, really liked the truck, was last year with 4 way disc brakes. Would think it will be easier to find a 2500 rather than a 1500HD. What is your budget, have you thought about a Duramax from that era?
Budget is the $5K range. I'm not really looking for a 1500hd. Will either go 1500 5.3 or 2500 6.0
17 hours ago, Bxnanaz said:
I've thought about a 2500 with the 6.0 but the gas mileage is just awful on a 6.0
True. I have a 7.4 and I get as good or better.
However, for towing the kind of weight you want to tow, I suspect a 1500 isn't enough truck. Get a scaled weight on your fully loaded trailer, then consult the owner's manuals, which you can find online. Then you can pick out the appropriate truck and drive train.
Buddy of mine has '12 5.3,tows alot locally, no matter how he loads the trailer,it's felt in the seat,doable,yes, drive with respect to the max on the truck,yno,don't be late and try to make up time
How often/far will you be towing?  For frequent towing and longer hauls, IMHO a 2500 will be the way to go.  Yes, the mileage isn't as good, but they're completely bulletproof trucks.  Buy once, cry once.
Yes, a half-ton should be able to tow your trailer.  I towed as heavy as 7,000 lbs with my half-ton '01, including into the Rockies.  The rear axle is the weak link on these trucks.  The 5.3 motor from those years is awesome.
2003 was the mid-cycle refresh for the platform - new gauges/steering wheel/electronics, etc.  If I was in the market, I'd be looking 2004-2006.
If you really want crappy mileage, go find an 8.1 2500.  :-)
Should think about a 2500 with a Duramax. imo I cannot believe though how even the gmt800 diesel trucks are hold there value.
