Need help choosing the right 33x12.5 and 20x12 set up. Thinking BDS or Zone 4"
  • Replies 161
I mean I can afford it now. I just have always been a budget and best deal sort of person. I definitely don't think I need to spend the extra $1200 for coilovers. Shes a pavement queen that might see a trail here and there or hunting trail but that's it. I think spending the extra few hundred for either BDS or CST will be worth it. I just asked the shop what price they have for all of them. I'll go with what feels right. I dont want to skimp out now and regret it in a few months cause I'm only doing it once.
For CST does it have the ability to go from 4.5" o 6.5" lift at a later time like the zone/ BDS?
I want you to call CST Performance Suspension tomorrow, ask them anything you want, great customer service. In addition, ask them if you can get the 20% off now without waiting on the sale. It’s a no brainer, if you were to compare a BDS lift to a CST lift, CST is far superior in build quality especially since they’re about the same price. Price them out yourself, BDS 4.5” lift and CST without shocks and see for yourself.
Sent from above
Reason I was asking your wheel and tire setup is that you can still run your stock wheels with CST and up to 35” tires, zero spacers too. Save up for wheels later. How do ya like dat!
Sent from above
I think a company's warranty speaks to what they think of the durability/reliability.  Some of these companies we are discussing have lifetime "no questions asked" warranties.
Sent from above
I have stock rims and whatever tires it came with. They are pretty terrible.
I don't want to run 35s cause I only have the v6 and just dont want that heavy or to go that high.
Plan is 18x10 -25 rims with 33s. It's only slightly bigger than stock but gives me an wider stance which is what I like.
Sent from above
I'm using my stock 20" wheels with 35x12.5 tires and zero spacers also so CST isn't the only brand to allow that.
That’s cause that’s their main selling points to get you to buy it and I’m sure a great number of BDS along with every other manufacturer customers have had their warranties rejected in the event of obvious abuse. Warranty is a great attraction especially to those that expect free stuff after abusing it. CST lifts have been known to be in head on collisions and zero damages. Because CST is a Performance Suspension manufacturer their products are mostly abused and as with ANY and ALL custom manufacturer they know if it’s been abused or not.
Sent from above
That’s not a BDS, you asked about the difference between CST and BDS, that’s a garbage Rough Country bracket lift you’re talking about.
Sent from above
Sent from above
What's not a BDS?
Sent from above
Also, BDS doesn't care if their stuff is "abused" or not.  If it breaks, they replace it.
Just advised you on saving money, having the option buying wheels later. I’m running 34” Nitto Ridge Grapplers and there’s a few in here running 33’s with their CST lift. I’m not a wheel expert with offsets. Zone and BDS are not bad lifts, just different quality and setups.
Sent from above
I feel like the BDS warranty is better than CST cause its no questions asked. But CST does seem to be good quality and how likely am I to actually break something with just street driving?? If it was going to see trails or rocks I'd be more concerned about warranty and even then BDS would be a better option.
I know the shops running a 10% off BDS right now
That’s great, so does Rough Country which doesn’t mean anyone should go out and buy one cause you get free stuff lol
Sent from above
50% off on install if you buy through 4WHEELPARTS whether CST or BDS or Zone. I’d still call CST with any and all of your questions and concerns. Get the Zone and have it painted with your favorite color since you’re saving hundreds with it.
Sent from above
Almost forgot, don’t forget to add the cost of questionable spacers and professional install. Good luck and do keep us updated.
Ok, I’m outta here, Apple store has some AirPods waiting for me.
Sent from above
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
