Electronic gremlins.
Jimmyboy63
2014 GMC Sierra 4x4 5.3
Bought it used about 2 weeks ago with 62k miles. 3 or 4 times, up on starting the truck, "service security/anti theft system" pops up on the dash and the clock resets to noon. Otherwise it runs, and everything functions just fine.
On Friday, I had all 4 windows cracked while driving, I rolled up both front windows simultaneously. When I did that, the headlights and all interior lights cut out for less than a second and the clock reset to noon.
Last night, taking a corner on a snowy road in 2wd, the back end slid and the stability control kicked in. When it did, the headlights and all interior lighting went out for less than a second. "Service stabilitrack" popped up on the dash and the clock reset to noon.
I had the battery tested today and it checked out just fine. The volt gauge reads just over 14v on startup, but drops to barely below 14v once the engine is warmed up.
I'm really confused here. Not sure wtf is going on. It's still under factory warranty, so I'll be calling my local dealer Monday morning. But I feel like this is one of those rare gremlin issues where they wont be able to replicate the issue and they'll tell me everything checks out ok. I'm really at a loss.
Any help or tips are appreciated.
Thanks.
Sent from my SM-G960U using Tapatalk
36 minutes ago, DeePa said:
Battery cables and a ground for the bcm under the drivers side dash speaker are well documented issues with the 14s
X2...
Thanks. Do you know how best to access that? Remove speaker grill and speaker?
Thanks! I actually found his thread after googling a bit. I'm fairly positive I have the same issue. I'll be ripping into the dash after work tonight.
Go to dealer had just ask for All the printed codes. It will say voltage low xxxx then you know it is the bcm ground and you fix it and life goes on.
My steering (when cold outside) was hard to turn. Took it in and the tech let me know he found the dome lights dimming when turning left or right. Here’s a copy of work performed, replaced the negative battery cable.
Sent from above
Sent from above
Glad ya got that figured out and fixed!
Yes, it almost felt like the older cars with no power steering and be fine once it warmed up. Strange how a cable could cause it.
Sent from above
Sent from above
The more I think I know the more I know I don't know :(
The more I think I know the more I know I don't know [emoji20]
Not like the old days, Electronic everything now a days.
Sent from above
Have a 2018 GMC 2500 with the L5P. Have not been pleased with this truck at all. Everyday the drivers side window won’t work for 30 mins to 4 hours. Then the DIC says open and close to relearn I’m sure. The def level says 218 miles one day. Two days later says ok. 3 days later days 298 miles. This truck is about to land on a used lot at the ford house. About to wash my hands of GM for good unless 1980 or older.
Anyone else have this issue as the dealer had the deer in the headlights look.
Truck has been doing this for months. Has 18,000 miles as of today and 5 months old.
  • 3 weeks later...
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
