CST 4.5” lift- what stops down travel?
4 minutes ago, AJMBLAZER said:
There definitely should be some kind if physical/mechanical stop to upward and downward travel. The struts should not be it.
This how I was thinking, seems like a lot of stress to the shocks/mounts/bushings otherwise.  The below article talks about overextended suspension and adding straps to limit down travel. I wonder if straps should be added to CST lifts given the removal of bump stops. Check out the pic and description of the messed up bushing on the shocks lower mount, which was caused by excessive droop/extension/downward travel.
https://www.drivingline.com/articles/how-to-protect-your-ifs-with-limit-straps/
I completely see your concern. But the thin pc of bump stop that was removed was in no way capable of keeping the lifted suspension from bottoming out. I’m completely interested in doing whatever and everything needed to keep my suspension in excellent working condition but I do not see the point of limiting suspension with straps unless you’re planning on jumping dunes or equivalent which in that case I’d highly recommend more than a medium travel suspension. My installer did mention to me that unless I’m planning on jumping 10’ in the air or as mentioned, dunes, then there’s no way I’m going to damage the suspension.
Sent from above
  • 5 months later...
On 2/18/2019 at 6:41 AM, TXGREEK said:
In addition to the design of the kit which limits any bottoming out, the shocks also have built in bump stops too. Btw, calling CST is the best way to get your question answered.
Sent from above
I know this thread is a bit old but looking seriously the CST lift for my truck. I had a question, how did you decide on the CST Coilovers vs' Fox or King? I'm sure CST will say they are just as good or better but curious if you researched it and what made you decide on the CST coilovers.
Posted a reply but didn’t show up. Ok, I went with CST Coil Overs cause they’re built by the awesome people that build the heavy duty lift so it only made sense especially cause a few people have done the same and only have great reviews on them. I may swap mine out for the adjustable versions so I can tune them based on the road service I’m on. I off road a bit when I hog hunt and have zero complaints.
  • 7 months later...
Hey guys, old thread I know, but I'm looking hard at the CST 4.5" lift for my 2018 Silverado.  Since some of you have it, does the kit require any cutting or permanent removal or alteration of any frame or crossmember parts of the truck?  I've also looked at the Cognito, but I don't like that it kicks your wheels out a couple inches on each side.
There's definitely cutting involved, The rear LCA mount on the drivers side has to be cut in order to drop the front Dif, like all full lifts. Also the UCA mounts have to be trimmed and the droop stops are removed to install the new brackets. No cutting or removing fins on the front diff is required like some others.
Here's a link to an installation.
http://www.trucktrend.com/how-to/chassis-suspension/1705-lifting-a-2017-silverado-1500-z71-with-cst-and-deaver
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 698 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
