Viktorrocks15 Posted March 2, 2019 Author Posted March 2, 2019 Did you get both driver and passenger seats powered? I currently have driver powered but will kill to have passenger powered.Sent from my SM-G955U using TapatalkYes. Both of them have power. The man who wrote all that about the seats with memory, non memory is Phil Gamboa and lucky me he lives about 40 min from where I live., so he does everything required to make them work as factory. With that being said, there’s a lot of work, wiring and improvising (sometimes) to accomplish this.Sent from my iPhone using Tapatalk
SirenRed16 Posted March 2, 2019 Posted March 2, 2019 Since yours is a LT check this thread out found this as I might add power to pass side on mine when I do the Katzkins later this year. I read a thread about adding power to passenger and I had to check the harness under the seat to check if I had power going there and I don't. I checked my dad's 2017 LT CC and he has the pins to add power to his passenger so I'm a bit confused why I don't. Sent from my SM-G955U using Tapatalk
Viktorrocks15 Posted March 2, 2019 Author Posted March 2, 2019 Every truck is different some have some wiring there and others don’t. Sent from my iPhone using Tapatalk
SirenRed16 Posted March 2, 2019 Posted March 2, 2019 Every truck is different some have some wiring there and others don’t. Sent from my iPhone using TapatalkYeah now my question is how do I get those neccessary pins there to have passenger power. Perhaps find a harness that has that pin and just connecting it?Sent from my SM-G955U using Tapatalk
Viktorrocks15 Posted March 2, 2019 Author Posted March 2, 2019 Yeah now my question is how do I get those neccessary pins there to have passenger power. Perhaps find a harness that has that pin and just connecting it?Sent from my SM-G955U using TapatalkContact@pgamboa he makes the harness that allows you to add the power need to make them work. That’s exactly what he did to my truck because I was pretty much missing everything..lol My seats were manual as the majority of WT are.Sent from my iPhone using Tapatalk
Enough Posted March 2, 2019 Posted March 2, 2019 One of my favorite things about this truck is the lack of an offset shark fin !! Sorry to hear you plan to add one. At least consider centering it on the roof like I wish GM had done ! It's a great looking truck and your mods let the guys with work trucks know they are not left out. Now that I've got a truck the same color as yours i am kind of partial to the color. They are Silverados after all. Not Bluerados, Rederados, Brownerados, etc.
SirenRed16 Posted March 2, 2019 Posted March 2, 2019 Contact[mention=159655]pgamboa[/mention] he makes the harness that allows you to add the power need to make them work. That’s exactly what he did to my truck because I was pretty much missing everything..lol My seats were manual as the majority of WT are.Sent from my iPhone using TapatalkI am going to send him a message right now. Sent from my SM-G955U using Tapatalk
Viktorrocks15 Posted March 2, 2019 Author Posted March 2, 2019 One of my favorite things about this truck is the lack of an offset shark fin !! Sorry to hear you plan to add one. At least consider centering it on the roof like I wish GM had done ! It's a great looking truck and your mods let the guys with work trucks know they are not left out. Now that I've got a truck the same color as yours i am kind of partial to the color. They are Silverados after all. Not Bluerados, Rederados, Brownerados, etc. [emoji14]The only reason I’ll probably have to still install the antenna where is supposed to be is because I will be adding a overhead harness for the sunvisor lights, radio antenna, and possibly adding the sliding rear window. I do like the idea of having the antenna in the middle like the Camaro. Will see... Sent from my iPhone using Tapatalk
Viktorrocks15 Posted March 2, 2019 Author Posted March 2, 2019 Not so regular anymore with that leather in there [emoji14]Best quote...[emoji1303][emoji471]Sent from my iPhone using Tapatalk
Enough Posted March 2, 2019 Posted March 2, 2019 24 minutes ago, Viktorrocks15 said: The only reason I’ll probably have to still install the antenna where is supposed to be is because I will be adding a overhead harness for the sunvisor lights, radio antenna, and possibly adding the sliding rear window. I do like the idea of having the antenna in the middle like the Camaro. Will see... Sent from my iPhone using Tapatalk With that Dallas neighbor of yours extending the cable for the fin should not be an issue. Phil could probably mount it on the rear bumper !
Viktorrocks15 Posted March 2, 2019 Author Posted March 2, 2019 With that Dallas neighbor of yours extending the cable for the fin should not be an issue. Phil could probably mount it on the rear bumper ! [emoji23] probably!!!Sent from my iPhone using Tapatalk
pgamboa Posted March 2, 2019 Posted March 2, 2019 Just finished this 2014 Single Cab today. No before pics since I started at 7pm last night until 11pm. Then all most of all day today....for anyone wondering why I haven’t responded to their PMs - LOL.Truck originally had cloth seats, manual adjust Driver/Passenger, Jump Seat, DL8 Mirrors, and Black Door Handles.Here is the after...And for anyone wondering.. Heat DOES NOT work . Owner wanted the synthesis trim (was black before) with inoperable buttons.Still trying to figure out how to add heat. At this time, BCM programming is needed to enable Serial Data Lin Bus #2 to output to the Heat Module. Maybe one day, I can use an aftermarket method, but using OEM switches/seats, bypassing the BCM enablement.Sent from my iPhone using Tapatalk
Enough Posted March 2, 2019 Posted March 2, 2019 Nothing like a RCSB Denali !! Great work as usual Phil !!
chris.luurtsema Posted March 3, 2019 Posted March 3, 2019 Looks great! I am curious about the functionality of the OEM heated seat buttons. I have always curious if the could be adapted to operate an aftermarket system. How unique is the function of the switch and could they be spliced into an after market setup? This would carry the benefit of Bypassing any BCM mods. Sent from my iPhone using Tapatalk
