On ‎3‎/‎5‎/‎2019 at 12:46 PM, z1boss said:
Here are the complete step by step instructions to get to the Passive door locks settings.
1.  From the main menu, click Settings.
2.  Click Vehicle in the top right corner.
3.  Click the down arrow to scroll down once and then click Remote Lock, Unlock, and Start.
4.  Click the down arrow to scroll down once and then you will see the two Passive door options.  From here, you will be able to change the settings.
Let me know if you try this and you dont have these options.  Just curious if my theory about Convenience Package 2 is correct.
Yep finally got it squared away, thanks for the help
On 3/3/2019 at 8:04 PM, towdog333 said:
Just found out that the door handle button locks the door but won't open ?????
Have a 2019 Tahoe only 12K miles that continues to have handle button issues. Have return to the service department 4 times only to hear "It's your problem" Chevrolet has "no Issues with any door buttons". Tahoe is back at the dealership again today, drivers button doesn't work. Now the service manager claims it's the antenna in the door not working? Claims Chevrolet knows about "some issues" but has no repair or knowledge of any issues. Ask that I come get the truck and keep using the FOB to lock and unlock the door. Anyone got the same issues or know the repair for this service group?
I have a 2019 gmc elevation that the doors will not unlock when the handle button is selected.   It worked yesterday.   Remote works fine locking and unlocking the doors
When select button all doors should unlock (passive door unlock setting)
If my key is in the same pocket as my phone the door handle buttons will not work. Switch the key to an empty pocket and works no problem. Just an FYI for you guys.
Sent from my ONEPLUS A6013 using Tapatalk
Thanks, although it’s not the problem.   This may be the result of me opening my truck windows with my remote and hitting several buttons before getting it right.  I’m not sure so I didn’t want to add it initially to add more confusion.
On 3/4/2019 at 2:43 PM, z1boss said:
Yeah that's a temporary disable with a re-enable.  If you go into   Settings>Vehicle>Remote Lock, Unlock, and Start you can set what the buttons do under Passive Door Lock and Passive Door Unlock.  Mine is set to unlock only drivers door if pressed once on the drivers door button and unlock all doors if pressed twice.  Pressing any door handle button while unlocked with lock all doors.  I also have automatic locking enabled for 5 secs after closing all doors
I have mine set to open all door with push of the button on the handle as long as I have fob in my pocket.
Thanks to the person that stated to press the lock/unlock button on the remote at the same time to make the outside door lock buttons work again.  That did the trick!!!
P.S. Don’t buy a new generation GMC Sierra 2019+ unless U like recall after recall, leaking window, flooded floor and no available parts (carpet) and a transmission that shifts like a 1972 dodge power wagon.     If no service fault indicator It can’t be fixed.
Sorry, GM owner but what piece of ’*^*%!   Chevy is having similar issues but not as bad as GMC.  JDP Initially quality my ass.  Maybe the last 2-3 years of a generation after years of figuring it out.
Anyway, thanks for your help. I’m sure I’ll be using this site a lot or banded from it.
Can you say 5 weeks, that is how long my brand new truck has been at the dealer   Do you know what GM offered me for the BS I had to deal with, free Onstar for a couple months.   Really!!!!
On 3/4/2019 at 11:46 AM, towdog333 said:
I didn't see anything in the setting menu for door handle locks, but will double check again. Plus they worked before and I know I didn't change nothing on any setting
Settings - Vehicle- - Remote Lock, Unlock,Start - Passive Door Unlock
I'm having a similar issue with my 2020 Sierra HD Denali. The doors will lock/unlock on both passenger door buttons, but not on either driver side doors!! any thoughts? TIA
Yes i have the same vehicle and mine just started doing the same thing  2019 GMC elevation !!
Nothing yet. I’m still within the warranty and soon will need an oil change. I’ll have them look at it then and post the “cure”
so have my truck in for this button problem. GMC is telling me that there is an antenna inside the door that
senses the fob, and that is what's wrong. They also said my drivers door window had been replaced since there was some shattered glass inside the door and whom ever replaced it did not replace an internal seal causing water to enter the door.
They think that's what caused the malfunction with the buttons on the driver's side. so they also have to order that seal but it's not covered under the warranty. Guess this is what happens when you buy a used vehicle (especially with low miles). Can't imagine that rain/water would have broken that antenna/feature in 13,400 miles!! When i pick the truck up i will question them more.
Edited by obazsm
On 9/8/2021 at 10:13 PM, Timothy Richardson said:
Thank you good luck
Locks are working properly, read above for the fix (at least what fixed mine)
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
