17 hours ago, gmdog2 said:
Has anyone experienced this on there 6.2 in the 19’s? I’m sure it’s the lifter/rocker arm deal..
Just curious, 1800 miles..
Thx
https://photos.app.goo.gl/XnasnRzKNwV3AWKp8
Sounds like the injectors firing to me, these direct injected motors sound like a box of rocks at idle.
  • Haha 1
Typically this "injector" noise does not start at only 1800 Miles.
Mark, you have a brand new truck. Take it to the dealer as it is under warranty.
On K2 trucks, some are noisy some are not.
A bad or broken lifter definitely is noticeable.
Cannot quite tell what your situation is from the video.
Well, took to the dealer. Needless to say I left without my truck. Apparently GM has a TSB on the this noise. They are ordering all new lifters, arms, etc. So we will see what happens. Thanks for the input.
Man.... never heard of this happening at only 1800 miles.
At least not on the K2 AFM engines.
You are the first I know of with the new 2019 DFM technology that has experienced this.
Did you notice any loss of power or mpg? Check engine light?
Well he didn't say it started at 1,800 miles, he said he had 1,800 miles.
Regardless i will check back to see the final diagnoses here because literally my 6.2 sounds identical to this and has for the last 5 years. I would think if i had a bent rod or collapsed lifter i would of noticed a engine light or decreased performance.
Nope... just kept getting louder in louder.  I’ve owned a lot of GM cars since I was 16. This is my first experience as well..truck ran great. When a guy asked me if I had the new diesel in it, I knew I had a problem?
Any update on this yet?  Mine 6.2 AT4 is noisy on cold startup, definitely sounds like a lifter noise,  truck has 125 miles on it.  Was yours noisy at start up as well?  Hate to have to take it in already, but from what I have seen online, thats its considered normal if it goes away in 10 minutes.
I've noticed mine does the same thing at cold start but it seems to go away after about 30 seconds. I was thinking about taking it in to the dealer but from what I've read, it's normal
I called the dealer this morning, he asked me to take a video of it.  He said sounds like they need to look at it, but will know for sure when he has his Techs look at it.  He said it could be a solenoid thats part of the vvt.  Mine goes away in about 2 seconds.   At first I thought it was because the truck sat over a week, but I started it last night and it did the same thing.  We will see tonight I guess.
Yes,  they replaced the lifters, gaskets, a few other things. Dealer stated that there is a TSB on it (TSB#PIP5606B) maybe? When I picked it up after the repair, it was much quieter. I have 2200 miles on it now and the tick is coming back and it sounds like I have an exhaust leak at the exhaust manifold and exhaust connection. It's going back in to the dealer Tuesday as I now have a check engine light on.  I called GM Customer Service on the issues and that has been a joke..I must say, disappointed in this unit. Trying to get a couple new 6.2's to compare mine..
As far as when the noise was present, mornings and after it warmed up. A little piston slap is common on cold starts and should go away less than a minute or so. Now my tick began as a piston slap in mornings, then just got worse as I drove it more. Then it was constant, never went away. I complained about the tick at 818 miles and took it in to the dealer..they wanted a video, got it, helped then diagnose it. I will say that the performance of the 6.2 is awesome!!
I had a 16 5.3 that had a slight dry start slap, had 50k miles on it, ran like a beast.
I think that is completely fine..of course, I'm not a technician or engineer for GM, but I did sleep at  Sleep Doctor last night..:D
  • Haha 1
Hey Gary, sound normal..I would keep an eye on it..mine started slow and grew into a diesel:rolleyes:
18 hours ago, gmcsierra71 said:
Any update on the fix for this ticking sound?
See info below..thx
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
