opinions on these led lights
anyone use these lights       https://www.superbrightleds.com/moreinfo/low-beam-headlight-bulb/h11-led-fanless-headlight-conversion-kit-with-adjustable-color-temperature-and-compact-heat-sinks-5000-lumensset/4445/9995/?make=16&model=1507&scc_id=1400&ye   my stock lights seem more like fog lights as they seem to be more of an amber color than the old h11 style bulbs that i am use to being at least a dull white tia
4 hours ago, avalonandl said:
Recommend you try Silverstar ZXE. LED's are not bright enough.
thank you is that true they are only good for a hundred hours seems kind of a short life for them
8 hours ago, jerseytaylor said:
run a true HID setup. no autozone bulb/sylvania whatever can compete.
thanks do you have any links to good hid that will work on my truck
On 3/11/2019 at 2:53 PM, jerseytaylor said:
theretrofitsource.com thanks will look them up
  • 5 months later...
YUP DID A FULL MORIMOTO RETRO FIT.... BEST DECISION EVER MADE HEAD LIGHTS AND FOG LIGHTS. DID THE SAME ON THE WIFE'S 2016 YUKON HIGH LOW AND FOG.
Meant to add that if you decide to try LED's, there is a thread on here I believe about using the V.4 LEDs also available through the above vendor...and some have suggested you could buy the same bulb for half the price elsewhere without the V.4 label.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
