I have swapped the steering wheel on my 2020 custom for a wheel from a 2020 LTZ. The wiring does not exist in the custom or WT trim trucks.
to make the radio/phone controls work here are the things that are needed: 1. A replacement steering wheel with controls,  2. Replaced wire harness in the column, and to the DIC and Headunit. (Possibly the clockspring, but I cannot conform that),  3. A replacement gauge cluster with the upgraded DIC,  4. A replacement head unit that allows for the steering wheel control input.
on top of that.... most likely going to need some programming for the ECU/DIC ..... at this time (2/19/2020) I don't believe anyone has actually completed a full swap of all these components to make it all work.
I really just wanted the leather wrapped wheel and used all the "guts/wiring" from my existing wheel to put into the leather wrapped shell.
Good job, Jason . Could one  also just replace  the steering control (part #6) and paddle (part # 3) , add the harness, cluster  and keep the existing steering wheel? See attachment. Thanks.
Perry
Perry
The radio controls are the paddle buttons on the back of the steering wheel, parts 7 & 8. Image is of the previous generation steering wheel but control layout is the same. Gonna take a wild guess that the holes on the back side probably aren’t even there on the base steering wheel (unless they put blank plates there).
Most likely you could.... but the audio control still isn't going to work without the head unit replacement, and programming to the ECU/DIC.
these new trucks are much more specific than the older models with the components.   Unfortunately you really can't just swap the parts in/out because the electronics are all controlled and monitored by the computers..... ?
I do have those controls from the steering wheel (audio control, rear paddles) if anyone wants them.... just pay the shipping for usps priority bubble envelope.
i can text pictures if someone wants them
I will take them if available
Hi Chris,
The hood was ordered by the  Chevy Dealership  Body Shop a several weeks ago and it is still on back order.I will keep you posted.
  • Thanks 1
4 hours ago, Pdubb Pdubb said:
Hi Chris,
I understand that, the fog lights I ordered were on back order for 2 months. There are some guys on here who have been waiting for fuel pumps for more than 4-5 months. I hope you hood arrives soon!
  • 7 months later...
On 12/21/2019 at 9:22 PM, redwngr said:
OTOH, it's' hard to believe people buy a $40k+ vehicle without ensuring it has the options that are important to them....
I did the same thing because to get those options you have to get one with that package and that was 6-12k more than my custom trail boss.
  • 1 month later...
I added a steering wheel with all the options on my Trail Boss Custom last night and the audio controls did not work. However, I might keep it because of the leather wrap.
not necessarily....its only about $1800 between a custom and LT trim and if you can buy and finance the right way you can save there too.....TB if needed/wanted is easy to replicate as well in aftermarket.....GM sells the kit so just depends how you go about the whole process....
adding interior is a PITA but suspension and tires is super easy
std LT Z71 4x4 all star and do gm lift for 1k.......add rims and tires when stock ones wear out....
Edited by Dunn
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
