Nitto Ridge 295/65r20 + 2018 Silverado 1500
On 3/27/2019 at 8:54 AM, Kyleorsini said:
I've got those in a 305/55/20 but with 20x10s and I rub full lock on billstein 5100s top setting
Sent from my Pixel 3 XL using Tapatalk
But you rub on the inner fender, not on the control arm or sway bar right?
52 minutes ago, Ge0rge said:
Great looking truck, like the clean look of it.
Much appreciated dude....I wanted something that looked better than stock without going too crazy. Guess I'm getting old lol
It does come with age. I now look at some vehicles and think WTH are they thinking. I prefer the stock look with a touch of making it your own now-a-days.
  • 1 year later...
Hello all, I have a 2020 Silveeado 4wd that I just put a 3 inch on the front and 2 inch blocks on the rear. I currently have the stock 20inch wheels in it with a 275/65/20. I am wondering if anyone has installed 295/65s or even the 305/60s on one yet? If so, can you give me details on rubbing and what all had to be trimmed if it was necessary. I am looking to buy tires this week for it.
Thanks
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
