LED Headlight Bulbs
Not sure if anyone has added LED headlight bulbs to their truck. I just added a set and now the dlr strip of LEDs are not lit up anymore instead the headlights are on. If anyone has any ideas please let me know. I'm new here just came from driving a AWD Toyota Sienna. We added a 4th kid so we need all the room we can get. Thanks
  • 3 weeks later...
Well I ran the same bulbs in the Toyota for 2 years without an issue, the improved light output is worth the headlights being on with the DRL's.
Agreed , was it an older toyota? Newer vehicles have complicated things going on . Google it and and you  will see possibilities.  Maybe you have  reverse polarity happening becuase led bulbs are reversed compared to your car. Ground  issues as a result of the aftermarket part not a right fit, the system  may now be failing it its initial  tests because of your  led kit causing drls to be disabled
With each new vehicle year cars are now designed for oem parts only more and more.  Try putting your original  lights back in is everything back to normal? If reverse polarity issue you may be able to reverse  the led plug.
It was a 2014, I will give that a shot, thanks.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
