Paint Chips in Bumper
16 hours ago, Ohiozr2 said:
I ordered the most expensive one. I won’t be able to get a perfect match with my color (diamond white), but if it covers the bare metal well I will be happy with it.
Agreed, this isn't a perfect solution that will have the same results as a complete paint repair/restoration but it will be the best DIY solution that costs you under $100. Paint pens/brushes look like globbed crap. Based on what I'm seeing with the Dr Colorchip kit this is the most control over the paint that you can achieve - and it's much quicker when you have a lot of chips (which is true in my case - front painted bumper is peppered). Kit should arrive this weekend or early next week, hoping to get time next weekend to touch up my truck.
I had the painted bumper chipping and rust issue on my last truck.  It didn’t have parking sensors so I ended up just replacing it with the chrome bumper for around $350.
On this new Denali, I am certainly going to try the PPF route and see if that fares any better.  I’m just debating how many other things I want to wrap with the PPF while I’m at it.
40 minutes ago, Loco-diablo said:
22 months into the xpel ultimate on my 2017 midnight edition.. still looks perfect... ZERO chips.
Got pictures of what it looks like?  Just curious if you can tell it is covered?
The link to my original post (pic in there) is in the second post on this thread... My truck is black, so the XPEL is difficult to see
On 4/2/2019 at 10:14 PM, mookdoc6 said:
Yup, I think the whole Blacked Out, Black wheel thing is a joke.  My brother just picked up a 2019 T1 and got the front chrome on his Silvy......Very Nice the truck looks great and it will wear better @80K too!
To each his own..black on black is beautiful!
The red GMC in this thread is a good example of what it looks like done both a good job and a bad job since it was done twice. I parked next to a coworker at work every day that drove a Silver Tundra and it took me 3 weeks to ever notice his front was done with ppf. Only way I even noticed it was edge were it they ended it on the hood and down the fender was shining in the sun one day. And I’m even a car guy...
I was not a big believer in putting 3M on the front, but after I bough the Corvette I had with it on already I became totally sold on it. I would never buy a new vehicle again with out having it put on. Especially one with a painted front bumper. It is a lifesaver especially up here in Canada or in Northern States were roads are sanded in winter.
I used the Dr Colorchip touchup paint yesterday and it was fairly easy to use. The color doesn't match great due to my trucks color, but for touchup paint I can't complain.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 581 Guests (See full list)
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
