Has anyone bought the accessory trailer camera that is sold by GM?  If so where does it plug in?  I watched a Youtube video that seems to show it plugged into the rear bumper but mine does not have a plug for it.  I have an AT4 with the trailer camera package.  Does the camera come with a new plug that needs to be installed?  Thanks.
I use it on the rear of the snowmobile trailer 28 foot
Plenty of cable it’s great to be able to see behind the trailer
 No it does not come with a plug
This is A picture of my trailer connector on the at4 with trailer camera package
 Did you also receive the trailer tire pressure monitors
I still have to install 4 tpm in trailer tires
So that is what is confusing me.  I don't have that plug configuration.  Did you have to purchase your camera or did it come with the truck?
My window sticker says the same thing you may want to check with your dealer
Did you receive the tire pressure monitors
Yes, they are in the center console.  So your truck had the trailer connector in the picture already installed?
Do you have a pic of the camera itself? How much was it?
Dennis, thanks again for your help!  With your information I was able to find a truck at the Dealer that had the correct trailer connector.  The sales person was skeptical even though my truck and his truck was equipped exactly the same.  So I went to the Service department and they contacted the Factory.  The Factory said that it must have left the Factory with the wrong trailer connector so they sent out the correct one.  It was installed today!
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
