Stabilitrack??'s
I know that I can turn off the stabilitrack but is there a way to make it stay off longer than 1 burn out? I have a supercharged truck and it's killing me that I have to stop and hold the button down for 10 seconds every time I want to go sideways.
Or you can unplug the steering sensor. Was a thread on that a few months back. I so that in the winter when the stabilitrak can be a real hindrance. You do have a message to clear each time you start up though.
Sent from my Moto Z2 Play using Tapatalk
The button or like a switch that disables the ABS/Stabilitrak would do it.
Where is the steering sensor located?  Won't that disable the ABS and Traction control too?  I would definitely need it on a switch.
On my 2014 it is above the pedals facing straight down, has four small wires inline. It pulled straight down without any retaining tabs.
And no it doesn't effect the abs or traction control.
Sabilitrack - Traction control - ABS,  are all tied together. I would not try anything that hasn't been proven!
Indeed, unplug it & go try the ABS & traction control on a wet or gravel road.
Mine both worked fine through the winter.
Stabilitrak affects AFM and vice versa.
Some engine failures have been linked to Stabilitrak.
Do you have a link to that thread? I seem to recall seeing something but can't find it now.
That's the one, thanks.
I was hoping someone came up with a method to wire that sensor to a toggle. I may have to go to a junkyard and grab a sensor and plug and see I can build a plugin that would allow for a switch.
Somebody said something about four wires but it looks like there might be as many as eight.
