I have been trying to ignore the first shift or two every morning. This morning I backed out and thought let me give it some gas instead of light throttle like I normally do. It had a huge hestiation on that first shift to the point it felt like it went into neutral and my body actually lunged forward in the seat before it slammed into 2nd. Felt like a 16 year old bucking the clutch on a manual. After that first shift it was back to normal.
What happens is and I know this from the Corvette forums over night the fluid drains back out of the torque converter so in the morning it just doesn't have enough fluid to give a proper shift. On the Corvette you can start the car first time and use the paddle shifter's to go from 1-2 and back again a couple times before selecting reverse or drive and doing this pressurizes the system enough to get a smooth 1 to two morning shift. Unfortunately we don't have this option on the trucks. You would think after 5 years GM would have come up with a fix for this.
It seems to be the worst when I park on my steep driveway engine uphill, then back out of the driveway. It hardly ever does it when it sits at work for 10 hours on level ground and put it straight into drive after startup. Also seems much worse when temp falls below 45.
But GM says it won't affect performance or longevity so we are forced to just accept it as is and move on as long as it only does it the first shift or two if the day.
Start parking backwards on your inclined driveway. ?
I backed into my inclined driveway and parked over night last night (not to help the trans, just for some other reason), and I actually noticed my shifts were SUPER smooth this AM.
So yeah, maybe this has something to do with oil getting into the torque converter?
Start parking backwards on your inclined driveway. [emoji16]
So there you all go. I solved the problem. That was easy.
On ‎4‎/‎29‎/‎2019 at 6:39 PM, Bmwtech113 said:
I have a 2019 AT4 with the 5.3l engine. I’ve had it for about a month now and I have noticed especially when I first take off after the truck has been sitting for a few hours that there is a jolt that will happen multiple times while accelerating up to speed. I’m not flooring it, just accelerating normally. It occurs between 10 and 50 mph and once it warms up then I never notice it again. Happens in D and also if it put it in L7 or L8. It feels like either a misfire or the transmission slipping. I just picked it up from my dealer tonight after they said “we’ve had other complaints but that’s just how it is.”
Has anyone else experienced this?
You should have "firm" shifts on warm up...after that it goes away?  It should even be stated in your manual I believe has to do with warming the fluid up quicker and reducing wear on components....
My main issue has nothing to do with shifting. Maybe I am describing it inaccurately but it is like a transmission slip that occurs multiple times over the course of a few seconds or like a stutter. It happens during acceleration from around 10mph up to 50 mph but not at shift points. If it were an all-wheel drive BMW I would say it feels exactly like the transfer case is slipping but I'm not sure the 4x4 system on these trucks works the same as the BMW all-wheel drive system.
Nope. Backed in last night. Still had hard 1-2 shift this morning.
Well that's disappointing. At least you tried!
My 8 speed has been unusually amazing the past week. I'm not sure if it knows how badly it's being talked about or what. Lol
Ever since the new fluid, I have not had the exact issue I originally had which was when going up a hill on a cold start the drivetrain would jolt or buck about 3 or 4 times in about a 5 second span.
I took the truck back this past Saturday for a harsh 1-2 and 2-1 shift. They basically told me it was normal and I have to admit the loaner truck felt the same at times as far as the 1-2 and 2-1 shifts.
However I still get a random jolt from the drivetrain. It doesn’t appear to be when shifting but it is at lower speeds between 10-50mph. The drivetrain on this truck in general feels like at times it doesn’t know what it wants to do and gets confused causing a rumble or clunk type feeling. Some of that may or may not be the DFM. One thing I did notice is that on the loaner they gave me (a Silverado LTZ 5.3) the engine rpms seemed to stay higher than what the rpms are at the same speeds on my AT4.
Well I spoke too soon about my original issue being fixed. It happened today. Going about 15-20mph through a neighborhood at constant throttle I felt a shudder and could even see the rpms fluctuating as it was happening. I’ll be back in touch with GM tomorrow.
mine does it to, also seems to take a couple seconds to go from reverse to drive, after the first 40 feet its fine.
  • 5 months later...
I have the same exact problem with my 2019 GMC Sierra.
The dealer told me GM will not pay for any repairs on this. UNBELIEVABLE !
I would never by another GM product and I suggest otherS to beware.
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
