5 minutes ago, Maize & Blue said:
Another thing to think about if their 1” rear lift block is really lifting the rear by 2” is your shock travel.  You’re going to bottom out your shock and will likely have a rough ride if you don’t replace the shock with a longer travel shock.
So far have not noticed any issues with ride or shock travel, but haven't done anything more extreme than a few speed bumps so far.  I'm thinking of keeping it how it is, looks more aggressive like that, and the front is up which is the issue that matters most to me.
If it's an issue probably whatever shock size they are using on the Trailboss would be right.
Edited by scdaren
Well I'm going on day 2 without my truck back. The 35x12.50s were too wide and kept hitting the control arm. Tire shop is ordering the 35x11.50s and they will be in tomorrow.
That sucks hopefully the thinner tire will fit. I just ordered 295/70s so a little under 35s and thinner too.
Is that with the stock wheels?
Yes stock 20s. The guy at the shop said it cleared turning so hopefully the 1/2" will let it clear the control arm.
1 hour ago, jb177 said:
Was it rubbing at full lock while in reverse like the older body style?
No, the inside of the tire was right against the ball joint when mounted to the truck.
Finally got it back. turned out pretty good in my opinion. 35x11.50r20 ridge grapplers have just enough space between ball joint and tire. No rubbing no trimming. They do run a little small so same size trail grapplers might require a little trimming.
  • Like 6
Looks awesome!  Thanks for posting this I have the same wheels and want to do something similar.  You said you have a 3" lift? Was it just the ball joint you are having issues with?  I have a 2" lift and I'm thinking those tires could fit with that lift as well.
Apparently they are different for the 19 (ford convert so not sure about previous models) and have a very small gap between the tire and ball joint. If you were going with aftermarket, I'm sure an offset would cure that but I wanted to stay stock for my wheels. I'd say nothing wider than right at 11.5" would work. The guy at the shop said they would have probably cleared with a 2" level but I wanted a little higher ride so went with 3" rough country.
Sweet... yeah I want to keep the stock wheels I have, just like yours.
Your truck looks pretty level -- is it actually level or do you still have a slight rake?
I believe it has a slight rake but I can barely tell.
Looks awesome man. I guess I'll be the guinea pig for the readylift 4"
  • 3 months later...
What do you think of the ridge grapplers? I've always ran trail grapplers.
  • 2 months later...
I used the Readylift level and I'm running 275/65/20 with no problem. I'm definitely looking into adding a block for the rear just so I can have that rake look.
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
