Rear diff cover?
Been searching for a new diff cover for my 12 bolt 9.5/9.75 axle.
Mag-Hytec apparently is building one
PPE doesn't have one,
I rather not run the AFE one.
Any other suggestions? Looking for one thats black with and oversized with fins.
Thank you!
Have you watched the mini series on youtube that Banks Power has done on diff covers yet?
It may change your mind if you do watch it, more fluid doesn't mean better cooling.
Get the PML cover.  I have a black one on order.  Same rounded shape as the stock cover to negate the "square-back" phenomenon Gale points out in his videos.  It holds about half a quart more but maintains the stock fluid level.
www.yourcovers.com
6 hours ago, ftwhite said:
B&M. I like the design and look.
This one has two through-bolts passing through the face of the cover with only blobs of RTV to seal them.  No thanks.
Thank you!
I have the G2....Works as intended which is adding more volume and ease of draining and filling etc.  No leaks had it 3years!
19k plus miles of short commutes, long trips and towing. No leaks. I am not sure how quickly gear oil could leak through threads on two bolts, but I imagine it is quite a while. Besides the oil level sits below the bolts. Mine is most definitely not flat backed. Just as rounded as the factory. But everyone has to rights to their own concerns.
