We went from 80 F and tornado warnings to the 20's and two inches of snow all in 36 hours. That there is some climate change. :crackup:
  • Sad 1
Pay no attention to it, just an anomaly...... that keeps repeating......
  • Haha 1
Again and again. :crackup:
Yesterday, upper 40's and raining with hail and tornado warnings. Over night 30's and snowing.
I'd like to thank DOG-e for laying off half the NOAA workforce slowing down the weather radio severe weather reports from soon enough to act and be prepared to 12-15 minutes after the fact. Great work! 😏
Weird weather yesterday. Started snowing corn snow, then started to hail, then we got lighting with the hail. 3 inches this morning, 23 degrees.
Wait until a real emergency they have cut back FEMA
Cumulus forming and dumping on us. From HEAT. We are hitting 60-70F here at 9000’ msl. That’s turning the standard lapse rate for temperature upside down.
29 this am here and clear. Soil is too dry.
86 here in Maryland yesterday almost turned the AC on. Getting ready to get the lawn equipment out from its winter break.
Edited by Silverado4x4
  • Haha 1
18” of snow overnight. Mid 20’s sun trying to pop out.
Just viewed a mountain lion chasing something across snowy ridge full speed.
Holy climate change Batman! Went from AC to heat before bedtime last night. Woke up to the 40s! Highs in the 50s today! It’s going to be like that most of this week! Brrrrr.🥶
We got 6 inches Friday.
19 this morning.
First morning above freezing.
We got an inch of snow, 30 degrees.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 283 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
