It was 18℉ this morning. Going to be 50℉ today. But next week we are only going to be in the 30's for highs.
10 degrees, 5 inches of snow and snowing. I'll take the moisture.
-11 degrees, 1 inch overnight.
On 1/15/2025 at 10:25 AM, KARNUT said:
Laughable south Texas forecast for next Tuesday. It started early with two days of snow and colder temperatures. Now the temperatures are forecast to warmer and less snow.
Yesterday was 60 dropping to 29 with a high of 44 today. The snow forecast is back on for Monday night through Tuesday morning.
One of my pet peeves of living in Texas is the whole idea of dripping faucets. Coming from New Jersey with basements that was unheard of. New Jersey is full of building regulations to protect the consumer that were slow to develop here in Texas. Of course they jumped the shark and over regulated. That seems always to be the case. When I built my retirement home in the back of my property I eliminated that possibility of frozen pipes. Our renters appreciate our efforts. The current long time two story in the front of the property is a pain to get the dripping right. A hard freeze is coming Tuesday night. In New Jersey it’s basically a normal winter night. So at the end of my ranting I’ll be little sleep that night getting up every couple of hours to check on the damn dripping because it’s going to hit 20 degrees and be under freezing for a few hours. 😡
  • Haha 1
-2 here today, -22 windchill, with a stringer of these in the forecast, -10 last night. Next Saturday is supposed to be a day with a few hours over freezing. Maybe I'll change oil. :crackup:
  • Haha 1
-30 F windchills tonight. -2 for the low and 0 for the high next 24 hours. Tight window, eh? Frostbite in 10 minutes is the warning.
On 1/19/2025 at 4:23 PM, customboss said:
Is that your front yard? Pretty!!!
  • Thanks 1
It's already -19 tonight, will dip lower. The high temp today was maybe -8 at best.
I drove even further north today for work, saw temps down around -20ish this morning.
Edited by CamGTP
Yes Sir!
  • Thanks 1
I just read -19  about 1/4 away in the creek bottom.
Yesterday's high was -2. Same temp now.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
