4 inches yesterday, 8 degrees this morning.
For whatever reason services here are salting like it Donner Pass and we haven't had enough snow this season to cover the grass. We had a week of temps in the teens and strong winds. Then a three day warm up before plunging us into what is predicted to be our first single digit temperatures of the season (Day time high).
  • 4 weeks later...
Finally getting some snow, not much so far. Snow is good for fire prevention when you live in the woods and have rentals rented by idiots. Like building a fire under a second story deck, happened a few years back, neighbor called the fire department.
Been cold though last few days.
  • Sad 1
We get same stuff here. VRBO and other rental services make us require a quick response Fire team.
https://pueblo.craigslist.org/hvo/d/fort-garland-pending-1977-intl-loadstar/7800556198.html
So how can they require faster fire service than the numerous home owners?
Land Owners association covers 15,000 acres. We got 1/4 of this place burned to ground in Spring Fire in 2018 by a drunk A -hole that was illegally burning trash in high winds just on other side of our properties.
Our quick reaction volunteers engage until
county VFD shows or it’s overwhelming.
Clarification VRBO AIRBNB don’t demand the fire response team our LOA did because VFD can’t get here for 45 mins since we are remote.
I can add to the thread now that I'm in PA and we have 8" and growing of snow and only 18º F.  Been this way since I got here last Thursday.  Trucks now happy.
We got 11" Sunday/Monday. Im ready for spring.
Will be in MacAlister Ok for the snow Thursday and Friday. Wait until Saturday to return to Texas.
We got 5 inches, 5 degrees. High of 25.
I’m getting ready to experience snow in MacAlister first since 2001 when I was working in Ohio. I grew up in NJ so I’m no stranger. The cold is not my friend anymore and don’t experience it much where I live now. I’ve had all this week sub 30 degrees. Don’t like it don’t want to get used to it again. I think I’ll wait to spring before I come this way again. You’ll can have it. I have to start the van at 20 degrees this morning. Ahhhhhh.
It’s almost here. 8-12 inches
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
