12v switch ideas
I am looking for a switch similar to those used on the dash for stabilitrak, etc. I want to mount it in the bottom front of the console to turn my amp off when needed. I prefer the switch to be recessed in a housing. Looking for suggestions...
Thanks
10 hours ago, 1SLOW1500 said:
I love these and they custom engrave them.df9fbe37d30e7009ab7b4d557694cc73.jpg
Looks good.
2 hours ago, [email protected] said:
I would look on Amazon and they've got 17 billion switches that you could choose from probably finding the exact same one that's on the dash
Already started searching, though searching through 17 billion is a mind-numbing task...lol.
Is this what you are looking for?
Its a GM upfitter switch plate which replaces your factory one with more aux positions. Depending on the model of truck you have determines how much more wiring and parts you need including a new fuse block under the hood. But this is the cleanest way to add switches. See the lengthy thread here:
That is nice but more money and as stated if your trim level.is higher you don't get that many switches. I get zero.
The aux switches are only an option on WT with plow prep I think. But the point is you can buy that new switch plate with up to 4 aux positions and add circuits to whatever you want. You just need to wire up the relays. The problem is that the wiring does not exist in most trims and you have to add new wiring and a new fuse block to make it work like the factory WT option.
