Thule Truck rack ??
I had a Trac rack / Thule ladder rack on my 2004 Ford ,I took it off and on more than once it had 4 ( FOUR ) Rubber blocks that installed  into bed pockets with Thick rectangle washer and bolt !
Here's the problem I ordered  the Thule/ trac rack for my 2016 GMC Sierra double cab I opened  box today for Base rails and found that hardware kit had ONLY TWO rubber blocks ( I immediately  thought I'm short two rubber  blocks  ) NOBODY is open till Tuesday to ask. Hardware kit also came with Two odd Aluminum  blocks, I'm not sure if installation  is New ( also NO instructions  ) Does anybody have this system  on there trucks???
Did you  install it ?? Did you have FOUR rubber  blocks on install or two rubber and two Aluminum  ??? Thanks Mike
Cant find ANYWHERE  !!! Called retailer they dont have it ! Called another retailer they didn't have it !!! Thule is closed till Tuesday,  I guess I'm dead in The water ! Even went to Thule website  ! I'm probably just missing parts  and that's it ! Thanks anyway !!!
Ok so The solution  is There is a ADDENDUM  ! The newer Gmc/ Chevy have two rubber blocks in front and two Aluminum  blocks in back  NOT four rubber blocks. Also I WAS missing  ALL hardware  for tool box mount kit AND one vertical rail WAS installed  Backwards at The Factory. The Thule/ Trac rac People finally took care of it sending out All necessary parts to rectify  situation. It was frustrating  but I can assemble it now this weekend,  I Hope NO OTHER Snags.I report back !
